Identify this pulley for me............ it's bent and creased on the outer lip, causing a knocking s
Old Jan 4, 2006 | 08:05 PM
Draggin99Si's Avatar
Default Identify this pulley for me............ it's bent and creased on the outer lip, causing a knocking s
Old Jan 4, 2006 | 08:42 PM
JDMegFERIO's Avatar
that is the a/c pulley that you are showing pics of. group 12 and 14 is group 3 broken down into two seperate packages. The part # for what you are looking for 38900-P2T-003 Clutch Set, Compressor. This includes the pulley and the balancer on the very end of the pulley, This is the package I would get. Hope this helps you out
Old Jan 4, 2006 | 08:48 PM
K20Ej1's Avatar
I see this car has been in a front end accident, thats probly y its bent. But yes that is the AC compressor pully and its # 12 on that diagram part #
Modified by SPOONedEJ1 at 3:08 PM 1/5/2006
Old Jan 4, 2006 | 09:30 PM
JDMegFERIO's Avatar
Diagram #16 and #24 is the tensioner pulley, this is the pulley that you will loosen and tighten to adjust the tightness of your a/c belt
Old Jan 4, 2006 | 09:36 PM
JDMegFERIO's Avatar
your trying to replace the pulley on the compressor. dia. #12 is the one you want to replace the pulley on the end of your a/c compressor
Old Jan 4, 2006 | 09:42 PM
JDMegFERIO's Avatar
hope this helped you out and get the car on the road soon with no problems good luck
Old Jan 4, 2006 | 10:44 PM
akteamster's Avatar
Default Re: (Draggin99Si)
not to thread jack........but what purpose to those frame locks serve exactly? extra reinforcement incase of a crash?
y not get some unorthodox racing underdrive pulleys while ur at it?
Old Jan 4, 2006 | 10:55 PM
Default Re: (akteamster)
http://korbachperformance.com/framelocks.htm
crxaddikt
Jun 20, 2014 06:11 PM
acmoc
11
Apr 29, 2009 11:59 AM
tag0617
Apr 12, 2009 06:13 PM
Indo boY
Apr 19, 2007 08:35 PM
See Are X
Jul 1, 2003 07:47 AM
