need help with rust behind gas fill door
Old Jan 4, 2006 | 07:53 PM
eda6's Avatar
Default need help with rust behind gas fill door
There were a couple spots of rust behind the gas fill door. As more paint was removed more rust appeared. Tomorrow i'll remove the rust seen in the pics, but i have a feeling there will be more lingering in that crevice (sp). This is my first attempt at containing rust. What needs to be done to make sure there's none hidden in that crevice? Thanks
<U></U>
Old Jan 4, 2006 | 08:34 PM
heyitzspikey's Avatar
look like whoever painted your car did not do a good job on preping it before they painted it....well sand the whole area down good where it is rusted..and prime it then re- paint
Old Jan 5, 2006 | 12:10 PM
Wilson_'s Avatar
Default Re: (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">i removed all the visable rust and now the metal underneath is discolored. Does this require more grinding? Is there anyway to make sure the rust is gone from areas i can't see w/o cutting?</TD></TR></TABLE>
use por-15 before you paint
http://www.por15.com/
Old Jan 6, 2006 | 12:06 AM
Shirk's Avatar
Default Re: need help with rust behind gas fill door (eda6)
I have rust in EXACTLY the same spot
Old Jan 6, 2006 | 05:11 AM
HT Chaplain's Avatar
Loved
Default Re: need help with rust behind gas fill door (Shirk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shirk &raquo;</TD></TR><TR><TD CLASS="quote">I have rust in EXACTLY the same spot </TD></TR></TABLE>
me 2
Old Jan 7, 2006 | 09:59 AM
alldz's Avatar
Default Re: need help with rust behind gas fill door (HT Chaplin)
Me 3!
to Ontario (Canada) winters!
Old Jan 31, 2006 | 02:02 PM
eda6's Avatar
Default Re: need help with rust behind gas fill door (alldz)
I just finished up a few other projects on the hatch and now i'm back to this one.
the results of navel jelly and an 18V drill with 2" wirewheel.
This side needed a second coat of jelly
after the 2nd coat
Used rags and carb cleaner to clean up. The gas fill door until i get some por-15 on thursday.
Old Feb 3, 2006 | 05:48 PM
eda6's Avatar
finally coated behind the gas fill door with por-15.
I have one more question..i'd like to check for rust in the gas fill area from inside the car. If i were to remove the seats and interior from the rear quarter panel, would i be able to see the the other side of the gas fill area from inside the car?
Modified by eda6 at 3:10 PM 2/5/2006
Old Feb 3, 2006 | 05:56 PM
si0385.'s Avatar
is there any rust on the rear 1/4's?
Old Feb 3, 2006 | 06:08 PM
eda6's Avatar
Default Re: need help with rust behind gas fill door (jaydeum4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeum4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">is there any rust on the rear 1/4's?</TD></TR></TABLE>
none on the outside, didn't look too hard inside the wheel wells though. I think the 1/4 panels are rust free. The car was in cali for 13 years and nevada for 3 years. Then i relocated to florida and I started having rust issues.
Old Feb 4, 2006 | 05:43 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">If i were to remove the seats and interior from the rear quarter panel, would i be able to see the the other side of the gas fill area from inside the car?</TD></TR></TABLE>
anyone?
Old Feb 4, 2006 | 09:23 PM
nelsmar's Avatar
seems liek you get a 100% clear view i cant remember....
Click for larger view
there is a pic of when i started stripping this crx out(new paint job inside and out) you can see it behind the speaker mount. is that what you were wanting? : ). this is in a crx but..... should be teh same.
Old Feb 5, 2006 | 11:00 AM
eda6's Avatar
Default Re: (nelsmar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nelsmar &raquo;</TD></TR><TR><TD CLASS="quote">is that what you were wanting? : ). this is in a crx but..... should be teh same.</TD></TR></TABLE>
yes that pic answers my question. Thank you
once i pull the interior and check it out i'll keep you guys updated.
i'm curious to see what's back there.
bouncy23
Jul 21, 2009 07:26 AM
JDM KID 510
16
Apr 20, 2006 03:33 PM
ieatrice
Nov 7, 2005 11:21 PM
DoughBoy387
Dec 7, 2004 08:20 PM
Heisdan
Jul 29, 2003 10:24 PM
