Questions on installing cams
Old Jan 4, 2006 | 07:52 PM
InvaderTrax's Avatar
Default Questions on installing cams
I'm getting ready to install my cams, and I have a few questions. I've got my manual, so I know the procedure, torque specs, etc. In the manual, it says I need to adjust my valve clearance. Do I need to? I just had them adjusted 2000 miles ago. And it mentions inserting 5mm punches into the holes near the cam gears. Does that just hold it still while I tighten it? And where do I apply the assembly lube? Everywhere? Just the lobes?
Old Jan 4, 2006 | 08:00 PM
CivicSiDriver02's Avatar
Default Re: Questions on installing cams (InvaderTrax)
I believe you are correct on the inserting the punches to hold the gears still and as far as the assembly lube i would put it every where you are going to have metal to metal contact. You can never have too much lubrication.
Old Jan 4, 2006 | 08:37 PM
Rosko's Avatar
Default Re: Questions on installing cams (CivicSiDriver02)
yes most definately readjust your valves, or at least check them.
lifeschase
Honda CR-V & Element
May 28, 2016 09:03 AM
Hondacivic90ed
31
Sep 16, 2014 11:18 AM
mastakmk
15
Oct 27, 2007 10:06 PM
jlows95ej1
10
Mar 15, 2005 03:57 AM
egsi32
19
Jan 6, 2005 06:44 PM
