in a 87 crx which model is best besides si? what do i need to look for?
Old Mar 19, 2002 | 03:40 PM
proalign6's Avatar
Default in a 87 crx which model is best besides si? what do i need to look for?
which car is better? what identifying marks do i need to look for? maybe something in the vin number? plz help
Old Mar 19, 2002 | 03:48 PM
Hcivic88's Avatar
Default Re: in a 87 crx which model is best besides si? what do i need to look for? (proalign6)
go here, it explains which digits in the vin number mean what http://www.quickhonda.net/index2.htm
hope this helps you a little
Old Mar 19, 2002 | 04:10 PM
Hcivic88's Avatar
Default Re: in a 87 crx which model is best besides si? what do i need to look for? (Hcivic88)
sorry, when u click on this link, click on the garage, and under that click on vin #'s explained
Old Mar 19, 2002 | 05:41 PM
Lt. Dan's Avatar
It's easy.. unless you are building a car for SCCA, I wouldn't use anything other than an Si... It's fuel injected, has bigger brakes, and a moonroof... To tell it apart from other CRXs, it's easy. Look for the power moonroof, body color moldings, exhaust exiting on the left side, and the most obvious part: the fuel injected motor. If you open the hood, and see a big air cleaner sitting on top of the motor, it's not an Si.
Dan
WestSide209
Dec 8, 2010 01:01 AM
krysted9354
Classic Hondas
Apr 7, 2009 06:20 PM
ALLOUT CL55
12
Feb 28, 2007 10:49 AM
zuich2ID
Feb 28, 2006 04:22 PM
xlur8ed
Jan 9, 2006 02:57 PM
