wtfZ0R is wrong with this new alternator belt?
It just won't go on..... too damn tight!!!
p/n: 31110-P73-A01
*edit*
this oem itr alternator belt is 30 5/8 inches in length.
the power steering belt is p/n: 56992-P72-004 and is 37 inches in length.
Damn you vortech, and this is why you should never buy a modded car.....
Modified by Black R at 11:32 PM 1/4/2006
p/n: 31110-P73-A01
*edit*
I saw in your other post that you have two different crank pulleys. If you are running the larger CRV pulley, this is why the stock P73 ITR belt will not fit.
That is a very good point.
I thought this larger pulley was the stock itr one, but I suppose I could be mistaken.....
How the hell am I going to find a belt that fits now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">That is a very good point.
I am pretty sure that the larger pulley is the CRV pulley. You can get an alternator belt for a CRV if this is the case. Or, if it is really close you can measure the length of the belt and go to autozone and ask for one that is an inch or so longer than the stock ITR application. Good Luck
</TD></TR></TABLE>I am pretty sure that the larger pulley is the CRV pulley. You can get an alternator belt for a CRV if this is the case. Or, if it is really close you can measure the length of the belt and go to autozone and ask for one that is an inch or so longer than the stock ITR application. Good Luck
T--Rex
Jul 14, 2004 04:44 PM
