New User-Tranny problem
didnt see a place to post this so i figured since i have a accord i just bought id put it here...any way, hopefully this as helpful as i was looking for...
just got my accord from a buddy of mine 92 2door coupe...pics come later i guess as i figure out how to use this site, but on to the car,
swapped 2.2 f22A1 (ive heard it came stock but in this car it didnt)
nuspeed headers
msd super 6 AL
aem intake (CA)
street and strip shift kit (auto tranny)
apexi n1 exhaust
sprint performance suspension
hi-compression valves and rods
konig rated R rims 17"
blackwidow bodykit
aerospeed predator style hood
primer white paint
My transmission is givin me a problem though... shifts fine 1st through 3rd and when you shift from 3rd to 4th it lags just a little...its not slipping when in gear, i heard that i needed to flush the fluid and refill after putting a new filter in but i have also heard this puts air into the transmission any help would be greatly apprecitated....
sorry bout so much in one topic just limited to 5 a day since im a new user
nuspeed headers
msd super 6 AL
aem intake (CA)
apexi n1 exhaust
blackwidow bodykit
primer white paint
A flush means changing the trans fluid 3 times, with a 15-20 mile drive between each change. Never heard of a trans filter though. Use only Honda ATF-Z1. you will need probably 10 quarts, maybe get an extra, just in case.
transmission filter kit??? i know they make one just not sure if they go in hondas or not i know everything else has them
this is my first honda i know absoultely nothing about them i can make it run and thats about it...i know engines and all but nothing to do with hondas i have always been a toyota owner...
Never heard of a kit either, don't know much about transmissions. All I know is use only Honda ATF-Z1, and change it twice as much as the manual sayes to. You have to keep the fluid as clean as possible.
[QUOTE=whytespyder]transmission filter kit??? i know they make one just not sure if they go in hondas or not i know everything else has them
QUOTE]
yep there are tranny filter kits available,, we install them all the time after replacing a tranny,, actually it comes with the reman tranny,, you install it online with the cooler lines ,, it is the only way the manufact warranties the tranny..
QUOTE]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH »</TD></TR><TR><TD CLASS="quote">Where do you get these things? and would it be a good idea to get one?</TD></TR></TABLE>
any extra filtering is always a good idea, especially one that you can replace.. as to where to get it ,,like i said it comes with the reman trannies we install..let me do some research .. let me call them up and see if someone can buy just the filters by itself ..but as far as i can tell is just on inline filter , hooked up to the cooler lines ,,
hatzipri90accord
Apr 1, 2011 12:10 AM
HondaDAMage626
Oct 14, 2008 05:53 AM
Badseed
Sep 30, 2008 11:45 AM
Kinnder
Jun 29, 2004 04:58 PM
