Crx B16 0bd0 w/type r intake mani what fuel rail/injectors?
Old Jan 4, 2006 | 05:06 PM
crx.com's Avatar
Default Crx B16 0bd0 w/type r intake mani what fuel rail/injectors?
I have a b16 that I intalled a type r intake manifold but the i'm using the type r fuel rail and injectors so the cars rund a little rich on fuel. I'm guessing its because of the satuarated injecters. I need to run ObdO peak and hold injectors but I don't know what fuel rail to use that will let me run Peak and hold injectors.
Any Suggestion.???????
Old Jan 4, 2006 | 05:35 PM
Rywire's Avatar
Default Re: Crx B16 0bd0 w/type r intake mani what fuel rail/injectors? (crx.com)
If you have the itr inj, cut off the inj box, and merge all 5 wires
Old Jan 4, 2006 | 05:42 PM
Crx Jimmy's Avatar
you can use the type r fuel rail with the stock injectors you dont need a special rail
Old Jan 4, 2006 | 05:58 PM
crx.com's Avatar
Default Re: Crx B16 0bd0 w/type r intake mani what fuel rail/injectors? (Crx Jimmy)
I tried using the 0bd0 but the injectors leaked fuel. I don't know why it was I think the injectors are shorter than the type r ones.
Old Jan 4, 2006 | 06:32 PM
KFBhonda's Avatar
i have the itr intake mani on my b16 and i use the stock b16 fuel rail b/c i lost the itr one. no probs here. but i have a GE rail that i will use in the future.
Old Jan 4, 2006 | 06:36 PM
Mr.Quang's Avatar
I am running a skunk2 manifold (same fuel rail mounting as the R) with a GSR fuel rail (should be basically the same as R's rail) with my stock obd 0 fuel injectors. The d15b2 I orginally had, used plastic spacers to space out the fuel rail, but they aren't used with my Skunk manifold. I had some leaks aswell when I first started it up. The problem was when I reinstalled the injectors into the fuel rail, the upper O-rings on the injectors torn/splitted. The solution is to go to advanced auto or autozone or where ever and get four fuel injector o-ring kit and replace all the o-rings on each injector. Also remember to add a small dab of grease on the o-rings so they dont get torn up when installing.
-[uSa]-Defcon_07
Jul 12, 2007 11:13 AM
zCivic
Feb 24, 2004 01:24 PM
ITRSpeed
Feb 3, 2004 03:42 PM
