Annoying problem
Old Jan 4, 2006 | 04:27 PM
Riceburner247's Avatar
Default Annoying problem
I'll just start where I noticed something was wrong.
Yesterday I was accelerating from a stop light in 1st, when at about 3k, my car stopped accelerating. It felt like it ran out of gas (my gauge says I have 1/3 tank left). I immediatly shifted to 2nd and kept accelerating and everything was fine. Accelerated from the next stoplight and the same thing happened. I immediatly shifted to 2nd and found that wasn't helping any. No matter how far I put my foot into the pedal, my car just acted like it was out of gas. Luckily I was able to coast into a parking lot.
Today I replaced cap & rotor and tried a few things. It came down to my plugs not firing and my fuel pump not priming. When I turned the ignition on, absolutely no fuel came out of the line going into the fuel filter. I would start the car (very hard to start), and it would run for a second or so, then die. Is it possible that the entire prolem is being caused by a faulty Main Relay? I'm stumped, so any input is appreciated.
Old Jan 4, 2006 | 04:43 PM
h224thgensedan's Avatar
Default Re: Annoying problem (Riceburner247)
I hade the same problem in my 3rd gen accord. I checked all of my grounds and replaced my main relay and it fixed my problem.
Old Jan 4, 2006 | 05:13 PM
Default Re: Annoying problem (h224thgensedan)
I'll be picking one up tomorrow. I'm thinking about running down to the gas station and getting some in a gas can. That would suck if my gauge was off and I'm just out of gas.
Anybody else?
Old Jan 4, 2006 | 05:32 PM
elrandeeto's Avatar
sound to me like main relay , i thought possibly moisture in your dizzy cam untill i saw u changed that and then the fuel issue , so im thinkin the main relay also
Old Jan 4, 2006 | 05:33 PM
payneth's Avatar
I am having the same problem and i think it is your main relay. I have to go pick one up to make sure, but it sounds like that might be the problem
Old Jan 4, 2006 | 06:16 PM
SiRay13's Avatar
sounds like the main relay, mine was acting line that for awhile, try cleaning the connection, if that doesn't help just replace it
Old Jan 4, 2006 | 07:10 PM
Default Re: Annoying problem (SiRay13)
Awesome guys, thanks a bunch. I'll be picking one up tomorrow as well, Payneth. I'll PM you and let you know how it goes.
Old Jan 5, 2006 | 04:25 PM
So I went to Honda today. If I order a main relay from them, it'll be here next wednesday.
Anybody else have any luck with theirs?
Old Jan 5, 2006 | 04:30 PM
crx90rcr's Avatar
umm to me it sounds like a bad ecu but i could b wrong
Old Jan 5, 2006 | 04:57 PM
Default Re: Annoying problem (crx90rcr)
Checked the ECU, everything is fine there.
ttcheung97
Aug 24, 2020 06:31 AM
CKnight90
Feb 9, 2014 06:23 PM
HondaTom87
Jan 9, 2011 11:15 AM
ek_b16
Mar 1, 2009 09:05 PM
97em1
Aug 13, 2007 07:36 AM
