obd1 or 2 for H22A?
yeah my h22a4 was obd2 but this h22a i received, im not sure. im going to try to remove the cover to see if i see a crank sensor. obd1 doesnt have one right?
The stamp is located under the heatshield for the exhaust manifold. Probably between #3 and #4 exhaust ports, I think. Thats the guarentee to see what motor you have. Take H22JDMEG advice to ensure you know exactly what you have.
92-96.all h22a's are jdm h22's which are all obd1's. the us version is the h22a1 which should be obd1 as well. if i am correct i believe the h22a4's are the ones that were in 97-01 and they are all obd2. stamp should be underneath were the upper radiator hose is located where the head and the block meets.
so seeing as how i have a 97 prelude which is obd2 and a jdm h22 which is obd1. what kind of problems if any am i going to have installing it since my mechanic doesnt seem to think it will work since he says its the wrong motor(4th gen) cuz it doesnt have a crank sensor? am i going to have to change my ecu or what?
i know a few people have gone with the 97-01 h22 version. most like the 92-96 obd1 because they are closed deck vs the 97-01 open deck. get the correct ecu for the correct motor. now if you want hondata, or crome or any of the other programs, yeah you have to convert to obd1. simply changing out the harness and i believe it require ditching the extra o2 sensor.
ok you have a 97 obd2 lude and a obd1 motor you want to put in. this is the easiest way.
keep your stock ecu
use the obd2 injectors, obd2 dizzy.
take the oil pump/crank sensor off the obd2 motor and place it on the obd 1 use the obd2 wire harness.
The knock sensor has a different plug. so either switch plugs or switch knock sensors.
as of right now I cant remeber if you need anyother sensors. just put the wire harness on and see if you are missing anything. there might be one or two more on the intake manifold/throttle body.
if you want to make sure use your obd2 intake manifold.
P.S. the 96 was obd2 but was not an h22a4
keep your stock ecu
I didnt quite do it like kulrevon said to do it... All I did was took the sensor wires that were down by the crank and fed them up to the dizzy on the obd1 engine, but I still used the obd1 dizzy cause thats where the sensors are on the obd1 engine... I dont think using the obd2 injectors will work cause those ones are saturated not peak and hold, im pretty sure I used the obd1 injectors in mine.
Oh I think I see what he is saying... Thats keeping it obd2 correct?... My way would convert it to obd1.
sorry to hijack the tread, after reading the post, I got 97 so is OBDII, can I put 95 tranny in it without any problem, I am a handy man but without knowleadge on electrical wiring, and I am gooing to do the 5spd swap, thanks for the help.
