grinding or squeaking noise from clutch pedal in my 2004 civic LX
Old Jan 4, 2006 | 03:58 PM
Sonic13v's Avatar
Default grinding or squeaking noise from clutch pedal in my 2004 civic LX
wow haven't updated this in a while. it was the clutch master cylinder. replaced under warranty thanks everyone. No more honda-tech for me. Good day all.
Modified by Sonic13v at 10:07 PM 12/4/2006
Old Jan 4, 2006 | 06:04 PM
EF-it's Avatar
two problems.
#1- where clutch pedal goes through the firewall into the clutch master cylinder it dries up and squeaks. Get some white lithium grease and spray onto pedal. (in the car attatched to pedal.)
#2- where the slave cylinder goes into the trans. it also dries up, removal of the slave is required and high temp grease put onto the end.
Old Jan 4, 2006 | 09:22 PM
31flavorscivic's Avatar
Default Re: (legunaef9)
Third problem:
Post this in the 2001+ forum, as you'll get more help there since most people here are still in the cable operated clutch days.
Magicdrag0n
Transmission & Drivetrain
Jul 17, 2018 01:33 AM
rawfish66
Oct 7, 2014 08:58 AM
K-Spec
Sep 26, 2006 11:30 PM
puertoroc7976
Sep 7, 2006 03:06 PM
LostAndFound
Jul 22, 2004 04:57 PM
