MINI-ME EXPERTS... PLEASE HELP!!!!
SO I DID MY MINI-ME SWAP WITH A SOHC ZC BLOCK, I HAVE A COUPLE OF QUESTIONS... 1ST, I'M BLOWING SMOKE THROUGH THE BREATHER ON THE VALVECOVER, COULD THAT BE THE PISTON RINGS.... 2ND, I'M USING A Z6 HEAD, WHAT DISTRIBUTOR WILL BOLT UP TO IT AND WILL THE WIRING BE THE SAME?????
You can use a 88-91 si/hf distriutor but have to hack it up to make it work..Best thing to do it convert to obd1,keep the stock d16z6 distributor and get a p28 ecu..
I'M CURRENTLY USING A 90' CRX HF/SI DISTRIBUTOR, AND ALSO HACKED IT OUT BUT IT STILL SEEMS LIKE THE TIMING IS OFF... ANY IDEAS ON HOW MUCH TO RETARD OR ADVANCE THE CAM GEAR, I HEARD YOU HAVE TO DO THAT...
jcrredrex2012
Apr 20, 2012 07:00 PM
The DX Rex
Oct 4, 2004 09:21 PM
Sirex
Mar 18, 2003 07:31 PM
