What Clutch would all of you recomend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi »</TD></TR><TR><TD CLASS="quote">Just bought an exedy racing organic from blue R..
I did the same but it really depends on mods. If you going for 500 WHP, an excedy OEM style probably won't hold, though an ACT 6 puck may be a bit much for a stock R with bolt ons.
What I'm getting at here is what supporting mods do you already have?
</TD></TR></TABLE>I did the same but it really depends on mods. If you going for 500 WHP, an excedy OEM style probably won't hold, though an ACT 6 puck may be a bit much for a stock R with bolt ons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekim952522000 »</TD></TR><TR><TD CLASS="quote">I like OEM
Ditto... But Honda specifically.
</TD></TR></TABLE>Ditto... But Honda specifically.
How much power/tq do you have and/or plan on making?
For near stock, you can't beat the price of the Exedy Organic.
For modified, I've been using the Exedy 3puck sprung disc + Fidanza Flywheel and it will hold the power no problem, and last a long time.
For lots and lots of power (ie: 400whp+) Clutchmasters twin disc or Tilton twin disc.
I run stock clutch disk with an Action 2000lbs pressure plate. Best from both worlds. Should be able to hold considerable more power than stock with no drawbacks.
I don't mean to thread-jack, but how much does it cost to replace a clutch if you supply the parts. I would probably go to the dealer since I don't know any local shops well enough.
I know it is possible to DIY but I'm not comfortable enough with how it is done to try on my baby.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 »</TD></TR><TR><TD CLASS="quote">
work for a dealer?</TD></TR></TABLE>
i'm sure he can replace your clutch on the side also
As i was saying to Blue R...
I have to admit that my car is not really all that stock, CTR intake cam,Mugen race ecu, light weight pulley's,spoon flywheel,jdm header, thermal tail section,ported head, and a few other things so i am running a stock disc for now but the new trans i just built has the 4.78 fd in it so i am a bit concerned about cooking a clutch.
I do a bunch of autox's and hpde days with this car so i am rather hard on parts..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Action Clutch.</TD></TR></TABLE>
What are your goals? Bolt ons, full build or boost?
I would say an OEM pressure plate and ACT strip/street disk with an Omni MC for anything that isn't over 200whp.
Boost or high hp --> ACT Xtreme PP and street disk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 »</TD></TR><TR><TD CLASS="quote">how much does it cost to replace a clutch if you supply the parts. I would probably go to the dealer since I don't know any local shops well enough.
Most shops charge anywhere from $200-$500 for labor alone. Dealership.....I don't even want to know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor »</TD></TR><TR><TD CLASS="quote">exedy organic</TD></TR></TABLE>
radicaled434
Jan 12, 2009 11:13 AM
TypeRuz
Nov 11, 2005 06:57 AM
kotetu
Jul 21, 2003 09:52 PM
