Do I need to reaplce my crankshaft pully bolt?
Old Jan 4, 2006 | 10:27 AM
citrus3000psi's Avatar
Default Do I need to reaplce my crankshaft pully bolt?
Just as the topic stated. I'm in the middle of changing the t-belt and wondered if it was necessary to get a new crankpully bolt.
I searched around and didn't see much in the subject and I don't remember the helms saying anything about it.
Thanks
-Dan
Dave_B's Avatar
I've never done it personally. Now if it looks damaged or anything that's different, but just a T belt change, I would make sure it's torque'd but that's about it.
Old Jan 4, 2006 | 10:29 AM
92TypeR's Avatar
FSAE
Default Re: (Dave_B)
I just looked at my Helms and it doesn't say to replace that bolt.
Unless the threads are damaged there is no reason to. Make sure you torque it correctly, but thats about it.
Old Jan 4, 2006 | 10:34 AM
Default Re: (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">I just looked at my Helms and it doesn't say to replace that bolt.
Nothing like saving money.
Old Jan 4, 2006 | 10:36 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (citrus3000psi)
There is no need unless damaged to replace the bolt.
Old Jan 4, 2006 | 10:24 PM
Black R's Avatar
25 Year Member
Default Re: Do I need to reaplce my crankshaft pully bolt? (citrus3000psi)
I replace with the timing belt or if it's been put on by someone else with an impact gun at greater than 130 ft-lb.....
Old Jan 4, 2006 | 10:32 PM
98 Spec R's Avatar
Just put a little bit of oil on it and you will be fine.
dephtone
Dec 1, 2008 06:59 AM
imadigitalgod
10
Jun 28, 2006 10:24 AM
LudeChild
Apr 7, 2005 02:36 AM
14bcoupe
Nov 22, 2004 06:57 AM
Renegade
15
Sep 22, 2003 06:28 AM
