Internal Wastegate -> External
I was wondering what was involved with welding an internal wastegate shut (for example on a 14B) to use an external wastegate. Just curious on the procedure, if anyones had any experiences with it.
If you get a new Downpipe for external wastegate then itll be blocked. If you going to use your internal wastegate manifold, just move the plate to where its closed and weld it to the downpipe.
