coolant leak in throttlebody
Old Jan 4, 2006 | 09:05 AM
mattssi's Avatar
Default coolant leak in throttlebody
I got my motor all together after having some major timing issues, and when i went to fill it up with coolant, I noticed it was streaming out of the throttlebody, when i opened up the throttle plate, about 20+ oz of fluid came out??? The motor is a stock gsr so you know how the intake manifold is shaped. No fluid was getting into the cylinders, I checked. Where could it be coming from? What should i replace. I have never driven this motor, still trying to get it going for the first time.
Old Jan 4, 2006 | 12:40 PM
devnull's Avatar
need a new tb gasket. Clean up all metal side of the intake manifold and the tb. Then try it again. and torque it down to spec.
Old Jan 4, 2006 | 02:34 PM
mattssi's Avatar
Default Re: (badboypolar2)
The throttlebody has never been removed from the manifold.. how would the gasket all of a sudden go bad?
sr20paisa
Oct 9, 2015 08:17 PM
holmesnmanny
Jun 9, 2012 11:33 AM
meccA's eg6
Honda S2000
Sep 5, 2007 04:31 PM
blackmfoggie
Jun 14, 2007 06:33 PM
EF4lyfe
11
Aug 27, 2004 12:23 PM
