Help....EF sedan sometimes has no heat....what could it be????
ok, sometimes the car acts up. its a 90 Ex Civic.....problem is that soemtimes, when u turn on the heat, the radio does not work. Then u shut off the radio and the heat works...The other day the heat was not working at all. Now, its fine, but I would like to know what it could be for when it does it again.
Anyone have any ideas as to what it could be?
sounds like you got a nice electrical problem. Could be a ground or wires are shorting againest each other. Wouldn't know for sure unless I looked at it.
Pull both out and look are the wires and check all the grounds and fuses
