Hondata S200 Blubox!!! Cheap
I got a Hondata Box that im not using. Asking 300 Firm for it. Brand new never used. Had Boost and 3 step Options. Your savin a bunch. Check the retail below
The s200 system has the following features:
Speed limiter removed (if applicable).
Tunable fuel and ignition tables.
Expanded fuel & ignition tables for boost.
Expanded rpm fuel & ignition tables.
A/C cutout.
Shift light.
VTEC control.
Adjustable rev limiter.
Launch control.
Full throttle shift.
Nitrous Control
Datalogging with HondaLogger software.
Datalogging with Palmlog software
ROM Editor tuning software.
s200 Pricing and Options
The base price for the s200 is $295 This allows the ECU to be tuned by a dealer or anyone with ROM Editor V3 and a programmer. You will need a base program (ROM) for your vehicle/engine/ECU which you can get from your dealer.
Price Description
$295 Base s200 system - Datalogging, 3- step rev limiter, speed limiter removed (if applicable), tunable fuel and ignition tables, expanded rpm fuel & ignition tables, VTEC control, adjustable rev limiter.
Various additional options are available, either when the unit is ordered or as an upgrade later:
Price Description
$50 3 step rev limiter- Launch control and full throttle shift. (optional upgrade on systems purchased before 3/1/05)
$200 Boost capability. Needed for turbo or supercharged applications
A/C cutout.
Shift light.
VTEC control.
Launch control.
Nitrous Control
Price Description
Price Description
