Bouncing and then dying tach
Old Jan 4, 2006 | 07:29 AM
Apd3111's Avatar
Default Bouncing and then dying tach
I have a 95 EX v6 and after its running for a while the tach starts to bounce around and then eventually just dies and sits at zero. I did put new gauges in but i dont think thats it as i replaced the tach which was bouncing before. Also the car kind of sputters when im driving on the highway going about 60-70. Its nothing i can hear i just feel it kinf of pausing for a second. but only when im at high speeds. Any help is appreciated thanks.
Old Jan 4, 2006 | 09:42 AM
Ross 2.0's Avatar
In a Junkyard near you.
Sounds like you have a dying ignitor. If your car has under 150K miles that is still under warranty. Take it to your dealer explain what you just did and they will cover it free.
Old Jan 4, 2006 | 10:27 AM
kulrevon's Avatar
Default Re: (MooGoCow3)
+1 on bad ignitor or bad connections to ignitor.
Old Jan 4, 2006 | 02:01 PM
SpeedFreak77's Avatar
Default Re: (kulrevon)
Mine did the same thing when I swapped engines. I ended up just buying a new distributor for about $40 more than what it cost me for an ignitor. Not saying that you should do the same but the distributor I received wasn't looking too hot.
Old Jan 4, 2006 | 02:45 PM
hondadude's Avatar
Default Re: Bouncing and then dying tach (Apd3111)
Bouncing tach is usually a sign of the coil shorting out under load, but a poor connection at the ignitor could also be a problem
hondacivic90zc
12
Jul 3, 2009 08:57 AM
saikouEF8
Jul 5, 2006 03:06 AM
De_tour
Dec 15, 2005 06:59 PM
dragonrcr
Sep 17, 2002 03:16 PM
B20zvtecek
Jun 24, 2002 06:47 AM
