quick question: will usdm itr fender liners fit the jdm front end?
Old Jan 4, 2006 | 07:14 AM
tuan...'s Avatar
Default quick question: will usdm itr fender liners fit the jdm front end?
yes or no? thanks
Old Jan 4, 2006 | 07:28 AM
SecretAgent's Avatar
i'm curious to know this as well.
Old Jan 4, 2006 | 07:35 AM
intekragsr's Avatar
Default Re: (SecretAgent)
lol i need to know also.
Old Jan 4, 2006 | 07:54 AM
tuan...'s Avatar
so much for the quick question part, lol
Old Jan 4, 2006 | 08:06 AM
Dave_B's Avatar
IIRC you can't. I remember seeing a thread about this roughly 3 months ago. I think the answer was no without some modification.
Old Jan 4, 2006 | 08:12 AM
tuan...'s Avatar
Default Re: (Dave_B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso (11:03 AM 1/4/2006): &raquo;</TD></TR><TR><TD CLASS="quote"> Duz not fit wif out modifitcations, You would be better off getting the correct one for your needs. Less chance of it getting rizipped out by the wheel and causing damage to the fender.</TD></TR></TABLE>
^had to quote him via pm because he was restricted to 5 posts a day
Old Jan 4, 2006 | 08:24 AM
JDM Factor's Avatar
They will fit, I've seen it done on a friends conversion, it basically bolted up without a problem.
Old Jan 4, 2006 | 08:26 AM
jomama's Avatar
need quick modifications to the liner
Old Jan 4, 2006 | 08:41 AM
Nishant's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">They will fit, I've seen it done on a friends conversion, it basically bolted up without a problem.</TD></TR></TABLE>
you need to make some cuts to make it fit properly. i just ordered jdm ones through password jdm
Old Jan 4, 2006 | 09:03 AM
intekragsr's Avatar
Default Re: (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">you need to make some cuts to make it fit properly. i just ordered jdm ones through password jdm</TD></TR></TABLE>
how much did that run you and does it come with the hardware to mount it?
Old Jan 4, 2006 | 09:15 AM
eluam's Avatar
Default Re: (intekragsr)
I never cut mine and they fit.
Old Jan 4, 2006 | 09:19 AM
intekragsr's Avatar
Default Re: (geeZus)
besides the fenders, what about the tray under the header?
Old Jan 4, 2006 | 09:27 AM
markpaco's Avatar
The JDM ones are the same as the USDM ones. The only difference is that there is a cut in the JDM ones. I used to have pics of it posted but no longer. The USDM ones have the scribe line to cut it and it is near where the bumper meets the fender. Sorry I don't have pics.
pec pec
Jan 12, 2007 10:58 AM
SOmbody
Jan 14, 2005 11:39 PM
RICE POLICE SIP
Apr 9, 2003 10:30 AM
MiraiZ
Jan 8, 2003 01:43 AM
Ibuprofen
Nov 18, 2001 10:20 AM
