where is solenoid valve B?
Old Jan 4, 2006 | 04:51 AM
aofemi's Avatar
Default where is solenoid valve B?
can someone lead to where the solenoid valve B is situated?
is it safe to buy a used solenoid or to go for a new one?
My car TCM code showed 8 blinks which reads faulty shift control solenoid valve B.
Thanks.
femi
Old Jan 4, 2006 | 05:58 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: where is solenoid valve B? (aofemi)
Maybe some more info like year/model/trim would help.
Also, I assume it's has an automatic tranny?
Old Jan 4, 2006 | 06:49 AM
aofemi's Avatar
Default Re: where is solenoid valve B? (TouringAccord)
Thanks so much.
i have a 1991 Honda accord EXR, 4 door and automatic Transmission.
Hope these will help.
Thnaks
femi
Old Jan 4, 2006 | 09:16 AM
H-T Order of Merit
I'm not exactly sure about the 90-93 Accords but my Helm manual for 94-95 Accords shows...
"The shifter control solenoid valves A/B and the lock-up control selonoid valve A/B are bolted on the outside of the torque converter housing."
From the picture, it looks like two small round towers. There are two similar looking assemblies like this. One is the shift control solenoid valve assembly and the other is the lock-up control selonoid valve assembly. They are located close to each other. From the looks, the shift control selonoid is located further down on the torque converter housing. So if you standing in front of your car looking into the engine bay, you'll see two of these assemblies located near each other on the torque converter housing near the motor. The one that is closest to the top of the torque converter housing is going to be the lock-up control selonoid valve assembly. The one below that, is going to the shift control selonoid valve assembly.
I hope that makes sence. If I was at home I could scan the picture from the manual and post it so you can see, but I'm at work right now. If you'd like though I can try doing that once I get home from work.
Also, keep in mind that this is for a 94-95 Accord with a 4spd automatic transmission. I would assume it would be pretty similar but I'm not sure.
Hope this helps you.
Old Jan 4, 2006 | 09:20 AM
H-T Order of Merit
actually, I found a diagram on SLHonda that shows the location of the shift control selonoid valve assembly. It appears to be the same as the 94-95 as shown in my manual.
Part #5 in the diagrams below is the shift control selonoid valve assembly
That should give you a good idea of where to look. As for which one of those towers is valve A and which is valve B, I don't know.
Old Jan 4, 2006 | 10:20 PM
aofemi's Avatar
Mr TouringAccord, thanks so much for oyur help. Indeed i hope it will be useful to me. I will show my mechanic the diagram ( we dont have much of good mechanics here). Will get back to you. Thanks once again
Femi
Old Jan 5, 2006 | 04:41 AM
H-T Order of Merit
no problem
Old Jan 5, 2006 | 05:16 AM
Honda-Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aofemi &raquo;</TD></TR><TR><TD CLASS="quote">can someone lead to where the solenoid valve B is situated?
Thanks.
femi </TD></TR></TABLE>
i replied to this in the other post you visited...... i even explained what to do ..
hotair
Nov 24, 2013 01:34 PM
Dave9212
May 21, 2008 07:08 AM
