Parts For Sale In Portland
Old Jan 3, 2006 | 10:39 PM
HondaBondMan's Avatar
B A N N E D
Default Parts For Sale In Portland
ALL at OBO...Moving and need it gone. Located in Portland, OR...can/will deliver if needed for extr $$.
Message me with number to contact you at. I am moving to California and need this gone in less than a month.
FOR SALE:
____________
OBD2 B-Series Distributor $130
B-Series Vehicle Speed Sensor VSS $20
obd0/1 Injector Resistor Box $10
OBD2 Injectors $30
1993 B16A ODB1 Throttle Body COMPLETE $70
2000 B16A2 ODB2 Throttle Body COMPLETE $70
2000 B16A2 obd2 EVAP Purge Valve $15
99 GSR/Integra IAT Sensor $10
B-Series Oil sender $10
92-95 Single Radiator w/ Overflow w/ 00 civic condenser fan and hoses $60
No Name 89-00 Civic 91+ Integra Lowering Springs $40
00 B16A2 Crankshaft $25
99 GSR B18C Rocker Arms w/ Shafts $50
00 Si clutch master cylinder w/resivour & slave cylinder $25
00 LS Water pump (10k) 3k miles $20
96-00 Civic stereo mount kit (maybe fit other cars too) $10
96-00 Civic Blower Motor for heat and such $15
2000 Civic Si power steering rack $30
00 Civic Si B-Series Upper Transmission Mount $15
22mm Mugen rear sway bar w/00 1 Si end links and reinforcment plates $100
00 Civic stock floor jack w/ tools $10
96-00 Civic Armrest Dark Gray no armrest pad $10
96-00 Civic Armrest eliminator Dark Gray $10
D-Series OE Wires from a 00 15k $10
NEW B20Vtec head gasket $40
99-00 Civic Door SHELLS ONLY BOTH $50
NEW B-Series b16/b18c Headgasket NEW $40
B-series AC Bracket Pulley JUST THE PULLEY AND ARM $10
Rear brackets for 99-00 Civic Center Console Bezel $10
Battery tie down OEM $10
Go Kart For Sale(6 HP Tecumseh Engine) REDONE Lokes Good $300 OBO
95 GSR Block w/ some parts & Tranny
- Spun Bearing on 1 rod. Could be polished or replace crank.
- Missing Head
- Transmission has like 5th/3rd gear busted
Project I started and dont have time. $800 OBO
SOLD
5-Zigen Fireball muffler welded to 2.2" staright piping fitted to EK SOLD
96-98 silver hood SOLD
00 Si prop valve (needed for 4-wheel disc upgrade) SOLD
EG Hood Primered OEM SOLD
HondaBondMan
Northwest (Sales)
Jan 22, 2006 05:16 PM
HondaBondMan
Northwest (Sales)
Nov 22, 2005 12:21 AM
HondaBondMan
Oct 22, 2005 11:31 PM
