I need pics of D16Y8's
i don't have pics but have done the swap and i think i had an extra coolant line that i ended up plugging
don't remember for sure but i will try and take pics when im back in town
what did you do with your IAT sensor
i just left m ine hanging
That is the white sensor found on the back/bottom of the D16Z6 correct? I haven't gotten that far yet as to decide what to do with it. Do you think I could grab one from a 2000 Civic Si that mounts in the intake, or is it a different signal? hmmmm
B
B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 »</TD></TR><TR><TD CLASS="quote">What exactly you needs pics of? I have a d16y8 and a digicam.
I need to see where the air and coolant lines go from the intake manifold.
B
</TD></TR></TABLE>I need to see where the air and coolant lines go from the intake manifold.
B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CivicSiBrian »</TD></TR><TR><TD CLASS="quote">I need to see where the air and coolant lines go from the intake manifold.
B</TD></TR></TABLE>
If I remember I will try to snap some pics tonight.
B</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 »</TD></TR><TR><TD CLASS="quote">Sent you a PM. </TD></TR></TABLE>
I must be dumb or blind because I can't find the 'link' to my PM box wtf.
B
B
your PM box is your instant message box.. just click that, and it will load a popup window *make sure u have your popup blocker disabled* and it will load with what message the guy sent to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">subscribing cause i'm going to be needing this stuff soon.</TD></TR></TABLE>
It helps to have alot of time to work with so you can sit one down beside the other. I'm still lost on the one thing. . . hoping for an answer soon. I have a friend with a '00 EX I'll take a look and holla.
B
B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InfiniteVTEC »</TD></TR><TR><TD CLASS="quote">umm I have a pic.... of my ride's d16Y8.
Which intake manifold is that? it is slightly different from mine.
B
</TD></TR></TABLE>Which intake manifold is that? it is slightly different from mine.
B
this doesn't help with intake manifold hose routing.
</TD></TR></TABLE>this doesn't help with intake manifold hose routing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dub C »</TD></TR><TR><TD CLASS="quote">red d16y8 valve cover is nasty looking
STFU
take your $ .02 back
</TD></TR></TABLE>STFU
this was from a previous post but maybe it can help you (disreguard the arrows, they have nothing to do w/ you situation.)
Modified by deadlock32 at 12:48 AM 1/22/2006
Eee Pee
Oct 4, 2003 05:59 AM
