welding fenders together.... what kind of welder should I buy???? pls help ASAP!
HARBOR FREIGHT 220 VOLT, 130 TIG/90 ARC WELDER INVERTER
http://www.harborfreight.com/c...91811
OR
HOBART 135 AMP HANDLER 135 MIG WELDER
http://www.harborfreight.com/c...55236
what one should I buy to use for welding a rsx half fender to a eg half fender? thin metal. Im also looking to use it in the furture for other projects, like welding on a exhuast and what not. shave doors possibly? please help me out and let me know which one would be more use. Thanks HT members in advance!
OR
neither...
youll probably need a nicer tig to handle that.
this project sounds a little odd. care to show us a pic of what youre talking about if you got the idea from anywhere?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand »</TD></TR><TR><TD CLASS="quote">
what one should I buy to use for welding a rsx half fender to a eg half fender? </TD></TR></TABLE>
im sure thats what he meant...
im doing a rsx front end conversion on a eg, i know both welders are not something a pro would use but im just seeing which would work better and im on a low buget so anything under 350 would be great. lmk thanks
its hard to weld thin metal with a crappy machine...
i guess go with the hobart, and get a gas setup. then weld and grind weld and grind.
start off with tacking it, then weld in the middle.
do you have a pic of someone whos done this before...that seems like it would look really bad...
have saw a guy on craigslist saleing his but its a ek 4 door ... i have a eg i just need to take couple spots and fiberglass the rest and body fill it. i dont really need to weld it competely together just like spot/tack welds. thanks for the help
ya its just to much trouble and time... i was going to do it but to think about it, probaby wont look that great and to much money..... well i guess ill have to fine me a stock eg hatchback bumper and hood. since i dont have neither. need car painted before feb. Thanks everyone. this can be closed!
