Sleeved Ls block, Manley,GSR head,GE head studs,Inline pro t4, MSD Digital 7
B18b Block with GE HD sleeves. Bore is 81mm so you have option to go as big as you want. Block is stepped decked. Comes with block,mains,bolts, oil pump,water pump, -10 tapped ls oil pan,windage tray, and etc.
Short block has a polished ls crank with manley turbo tuff rods. Pistons are JE dished 9.0 pistons. Assembled with acl bearings. bottom end has a little over 100 miles. I used it for one race and have decided to give up on the honda scene. Motor does not smoke and runs strong. Assembled I will Let it go for 2k obo. I will also part it out.
*SOLD*
SVE 3Bar Map sensor. Used for 100 miles works great. Comes with pigtail and wiring guide. $50
Socketed P28. Has datalogging port. Comes with burnable chip. . $175
'00 Complete gsr head. Stock and unmilled. Comes with head,bolts,caps, cam covers,dizzy,intake manifold,tb, sensor and etc. Also it has a pro-fab thermo gasket.
$600obo. Piture will be up later
Golden Eagle GSR Head studs. Has 100 miles. $75 Pictures will be up later
Inline Pro T4 Manifold. Brand new comes with 42mm wg flange. *SOLD*
MSD Digital 7 plus. Great condition. Come with everything you need. HVC2 coil. Msd dohc vtec cap and coil wire. $450
All prices are obo and without shipping. More picture aand parts to come.
Modified by SlowReaction at 8:44 AM 1/6/2006
Modified by SlowReaction at 8:45 AM 1/6/2006
Modified by SlowReaction at 8:50 AM 1/6/2006
Modified by SlowReaction at 8:51 AM 1/6/2006
Modified by SlowReaction at 8:52 AM 1/6/2006
Modified by SlowReaction at 5:47 PM 1/6/2006
*SOLD*
haha dam peter...you know you will change your mind in like a week..i wish i had money so i could buy it for a backup engine but anyways bump for a great seller with quality parts
i dont know if he is sellin the clutch...i think if he does one of our friends has called dibs on it already
