no start, continuous clicking, bat & starter tested good... JDM ZC DOHC
Old Jan 3, 2006 | 07:35 PM
ncskate's Avatar
Default no start, continuous clicking, bat & starter tested good... JDM ZC DOHC
i have a 93 del sol... im running a stock jdm zc dohc ive had for about 4,000 miles it cranked easily everytime until recently. it started just clicking continuously fast when i hold the ingition trying to crank it.
ive tested the starter and battery on advanced auto's tester they both came out good... all the grounds are good, the main relay is good.
please help if u have ANY idea what could help i have to drive this car 30 miles to work tomorrow because i gotta ticket on my parents transam and am no longer allowed to drive that
Old Jan 3, 2006 | 07:38 PM
9295EJ-t's Avatar
Default Re: no start, continuous clicking, bat & starter tested good... JDM ZC DOHC (ncskate)
if the battery and starter are good.. then check your ignition (cap, rotor, plugs, wires...etc..)
if you have to have it working by tomorrow, i suggest you try to push start it.. (if you have a 5-speed)
Old Jan 3, 2006 | 07:40 PM
tallyturbo's Avatar
Default Re: no start, continuous clicking, bat & starter tested good... JDM ZC DOHC (9295EJ-t)
do you have gas in the car? im just asking because i went to start mine yesterday and it didnt. i guess having no gas ownes me
Old Jan 3, 2006 | 07:41 PM
GdmLaz's Avatar
hmmmmm it just clicks and the battery is good
Really weird try push starting it to start with
Old Jan 3, 2006 | 08:08 PM
ncskate's Avatar
Default Re: (Slammed92hbonN20)
it will start EVENTUALLY if i hold the ignition but while its just clicking the motors not turning over... which rules out dizzy, cap, rotor etc... fuel pump primes. push starting works. it has a brand new headgasket and its smoking white really bad which is weird. bad thing is im a mechanic on suzuki's itll look nice push starting my honda to leave. but i gotta do what i gotta do.
Old Jan 3, 2006 | 08:13 PM
716pro's Avatar
Default Re: (ncskate)
check the ground on the tranny.
Old Jan 4, 2006 | 02:55 AM
ncskate's Avatar
Default Re: (716pro)
ive taken off all the grounds and put them back on plus added more, all grounds tight
Old Jan 4, 2006 | 03:15 AM
JimmyAtlantis's Avatar
Ignition switch?
Old Jan 4, 2006 | 06:12 AM
ncskate's Avatar
Default Re: (JimmyAtlantis)
this was one of my guess's also but obviously thats working because its sending power to something to click.. also i have power throughout the car when in the ON position the lights work the guages/cel, bat, etc lights work and stuff... dunno if that matters... anyhow i have the dash out and the clicking sound is coming from the engine area as well as the main relay area which on a 93 sol is right by the interior fuse box... the clicking i believe is coming from the interior fuse box actually because i can feel it through the black relay for i think the flashers on the fuse box. all fuses have been replaced... ALL of them
edit also when i try to crank it the rpm guage fluctuates but not high just 1 - 2 grand but the motors not turning over.
Old Jan 4, 2006 | 09:31 AM
716pro's Avatar
RECHECK the ground from body to the tranny, i couldnt start my f-ing car for a whole day because of that dam ground.
Old Jan 4, 2006 | 09:32 AM
ncskate's Avatar
did it click like mine is? im at work right now ill do it later my main question right now is could the start seem to be fine on the machine but actually be bad? i have a starter for an automatic at home but i dont think i have ne spare 5spds are there diff?
Old Jan 4, 2006 | 09:33 AM
Archidictus's Avatar
Unceasing Measure
Something's wrong with the battery power path. It's nothing wierd, it's just a simple case of power not getting where it should go.
Old Jan 4, 2006 | 09:38 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 716pro &raquo;</TD></TR><TR><TD CLASS="quote">check the ground on the tranny.</TD></TR></TABLE>
My friend has had the same problem. We thought it was the starter, so we swapped it yesterday, no go. We looked at the grounds on the tranny-frame and a couple by the IM and they were really corroded. We cleaned the **** outta it and it worked.
I know you said you already checked, but triple check it
Old Jan 4, 2006 | 09:50 AM
AutoXer's Avatar
Default Re: (SkoundrelUSA)
My friend also had a bad battery test 'good' at the parts store after he tried to jump it and it just clicked away. After everything else checked out, I hooked up the jumpers, ran my car at high idle for about 5 min, and his started right up. New batt, and everything is fine now.
Old Jan 4, 2006 | 06:28 PM
ncskate's Avatar
Default Re: (AutoXer)
this is freaking retarded... i came home and tried to crank it. it cranks fine, i tried it again in 30 mins... no problems.
now im wondering if the problem fixed its self how long ill have till it happends again in some odd place where i wont have tools.
any how thanks for all the replys i know grounds can be a pain in the *** i had a turbo d-series i drove all the way to myrtle beach from where i live which is like 4 hours almost with lights fickering and all kinds of weird stuff becaues the grounds were all loose b/c i didnt tighten them after putting the engine in the day before...
Old Jan 4, 2006 | 06:30 PM
.Beaver's Avatar
Bloody Beaver
make sure the solinoid (small wire on the starter) is plugged in. I've missed it before and it just clicks
GreenGoblinEF
13
Apr 30, 2010 05:33 PM
ZexyAccord
Jan 9, 2006 03:34 PM
amh0001
20
Oct 28, 2004 12:55 AM
ghost_ryder35
15
Mar 19, 2004 05:04 AM
Fatboy1985
Dec 26, 2003 02:38 AM
