The boucy tach is back
Old Jan 3, 2006 | 07:25 PM
N1ghtM0nkey's Avatar
Default The boucy tach is back
So I cured my bouncy tach problem awhile back by replacing the distributor with a known good working unit, only for it to come back a few months later. My old distributor was also causing a very severe miss at almost any RPM above 2,000 - made the car almost impossible to drive.
My question is this - what would cause an ignitor to go bad? Could my problem be something not related to the distributor? I've heard the alternator can cause the problem if it's going bad. Also I seem to have a low speed miss at idle, but not above idle...however I can detect no signs of a blown head gasket or bad rings, no burning of oil or coolant.
I just replaced my battery since it went bad...it seemed to be leaking acid, lot's of corrosion on my mounts.
Could this possibly be linked to a bad ground somewhere? I know for a fact I've got a short or a ground somewhere in my turning signal circuit but I haven't been able to track it down.
Any other thoughts?
Old Jan 4, 2006 | 05:20 AM
crex23's Avatar
Default Re: The boucy tach is back (N1ghtM0nkey)
First off, do you have any ECU codes? That will tell you alot right there. The next things that come to mind are bad ignitor, vaccum leak, or the TPS. Hope that helps, good luck.
Old Jan 4, 2006 | 08:12 AM
Default Re: The boucy tach is back (crex23)
No codes so far. I'll look into checking the TPS for any problems, thanks.
Old Jan 4, 2006 | 09:51 AM
Tyson's Avatar
just a thought, maybe buy some new spark plug wires.
i had randomly jumping tach before too, when i replaced it with another used distributor i put new plug wires on. its been fine.
hondacivic90zc
12
Jul 3, 2009 08:57 AM
WhiteEG6
May 20, 2004 03:57 AM
hyperlite1080
14
Apr 12, 2004 01:17 PM
raceboy71
Sep 3, 2002 02:33 PM
02WRX
Jun 30, 2002 08:03 PM
