Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Buddy Club N+ Suspension $799.99 + shipping
Old Jan 3, 2006 | 05:33 PM
Retired's Avatar
WEST COAST
Default Buddy Club N+ Suspension $799.99 + shipping
<FONT SIZE="5">Buddy Club N+ Suspension
$799.99 + shipping
</FONT>
All Kits come complete with Upper Pillar Mount! Dont be fooled by others!
Offer Available for EG, EK, TSX, DC2 & DC2 R
RSX EP3 S2000 now available !
Old Jan 3, 2006 | 06:45 PM
eg6ky's Avatar
can you post up some pics of what you have in stock?
Modified by eg6ky at 8:20 PM 1/3/2006
Old Jan 5, 2006 | 06:11 PM
Retired's Avatar
WEST COAST
Default Re: (eg6ky)
Yes sir will take some pics tommarow
Old Jan 5, 2006 | 06:26 PM
Scr4ppY's Avatar
Default Re: (iTunedUSA.com)
What are the specs on these coilovers? I was thinking about going with megans...can you tell me how much it is shipped to 77095
Old Jan 6, 2006 | 02:08 PM
Retired's Avatar
WEST COAST
Default Re: (Scr4ppY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scr4ppY &raquo;</TD></TR><TR><TD CLASS="quote">What are the specs on these coilovers? I was thinking about going with megans...can you tell me how much it is shipped to 77095</TD></TR></TABLE>
NEW!! BUDDY CLUB N+ SPEC DAMPER NEW!!
BRAND NEW! ALL NEW!!! "N+ SPEC DAMPER" from Buddy Club is the choice complete suspension setup with resemblance of our RACING SPEC damper's excellent attributes. It is cost effective and is well rounded for the budget minded weekend club racer. With optional urethane isolated aluminum upper mount design, engineered spring rates, 15 level damper adjustability, and ride height adjustment capabilities, the N+ SPEC DAMPER can accommodate any driver's preferences.
With over 15 years of competitive racing experience, you can trust that your car will perform the way you want it to with quality components from Buddy Club.
[ 1. Ride-Height Adjustable ]
Vehicle ride height is adjusted independently of spring pre-load. With other alternatives available on the market today, vehicle ride height is adjusted by reducing or increasing the preload on the coil spring. This primitive methold leads to inconsistent spring rates that are dependent upon the vehicle ride height. With any of the Buddy Club suspension components, including the N+ SPEC, vehicle ride height is independent of spring pre-load. This method ensures that the spring rate is always consistent, no matter how high or low your car is. In addition, it ensures that the spring is always properly positioned onto the strut and effectively reduces miscellaneous and unnessary noise.
[ 2. 15 Level Adjustment ]
Suspension adjustability is a key element when selecting a top quality coil-over system. The N+ SPEC DAMPERS are designed to accommodate a wide range of driving conditions from regular roads to prepared racing surfaces. Dampening settings ranges from hard (+4kg/mm) to soft (-4kg/mm).
Also avaialble is the optional urethane isolated upper pillow-ball mount. The urethane isolating ring keeps suspension noise to a minimal while maintaining the precision feel of a solid mounted strut.
[ 3. Mono-Tube type shell case ]
The shock-body is constructed out of cadmium plated steel and is finished with beautifully anodized precision CNC machined aluminum ends. Urethane bushings are used when applicable to ensure a top quality product.
[ 4. Exclusive Buddy Club Springs ]
In a complete suspension setup, the coil-spring is a very key element. The coil-springs used on all Buddy Club suspension setups are specially made to exacting specifications by Buddy Club engineers. Each coil spring is manufactured to exacting tolerances to ensure performance in every demanding situation.
[ 5. Beautifully Finished ]
To ensure that the N+ SPEC Dampers stay looking superb through your years and years of ownership, each precision CNC machined aluminum component is beautifully burgandy anodized and each steel component is cadmium plated for corrosion resistance. Great attention to detail was taken to ensure that you will be completely satisfied with your ownership of Buddy Club components.
[ 6. Prices starting at only $890/set! ]
With so many features, it's hard to believe that this suspension set starts at only $890.00 MSRP (without optional upper pillow-ball mounts)! You will be hard pressed to find a comparable suspension solution to suit your demanding needs. With Buddy Club, there is no trial and error. Complete sets with upper pillow-ball mounts start at only $1180.00 MSRP.
Buddy Club N+ SPEC Dampers come complete with all necessary adjusting tools and installation components. Installation can be performed by the avid do-it-yourselfer, and technical assistance and support is available by calling our office.
Old Jan 6, 2006 | 08:51 PM
Uncle Dave Macon's Avatar
CTRL C ownz u...
Old Jan 6, 2006 | 10:25 PM
microep3's Avatar
Default Re: (Uncle Dave Macon)
Damn, did these fall off the back of a truck?? LOL jk. That's a hot price.
where's the pic you're gonna take
Old Jan 10, 2006 | 06:50 PM
microep3's Avatar
Default Re: (microep3)
any pics yet? Surprised not more people are jumpin on this deal.....
Old Jan 11, 2006 | 12:51 PM
slvrnismo's Avatar
is it 799.99 + shipping for the dc5 also?
Old Jan 11, 2006 | 03:29 PM
eg6ky's Avatar
he told me 850 for dc5 but there's still no way. No one has posted up that they have gotten them, and one dude sent his money in.
Old Jan 12, 2006 | 08:07 AM
eboixing's Avatar
Default Re: (eg6ky)
i'm suppose to pick up a set for the dc5 from him locally. N+ are out of stock and will be back in stock for about 2weeks. And that is not from itunedusa but other companies too including BC
Old Jan 12, 2006 | 04:53 PM
eg6ky's Avatar
dude he said he had some in stock and he would take pics of them. HE DIDN"T take that as you wish..
Old Jan 12, 2006 | 08:03 PM
eboixing's Avatar
Default Re: (eg6ky)
well yea, we'll have to see. I'm going to call him once I get a confirmation from Buddyclub that the N+ are back in stock. Hopefully this is not some bullshit ad
Old Jan 13, 2006 | 05:06 AM
Buetang's Avatar
Default Re: Buddy Club N+ Suspension $799.99 + shipping (iTunedUSA.com)
Curious as to what the minimal drop is for these. I have some Omni's on my EK right now - and the highest ride height is way to low for my taste.
Any shots of them 'on car' ? (curious)
Old Jan 13, 2006 | 09:14 PM
Retired's Avatar
WEST COAST
Default Re: Buddy Club N+ Suspension $799.99 + shipping (Buetang)
Sorry to all customer we have been away dealing with some issues that needed to be taken care of and have lack on or customer service for the following weeks. We our back and in full order to take all your order and process them quickly and promptly. Any customer that have been incovinced with thier orders due to our companies delays have the option of a full refund all orders will be shipped promptly! Any question please contact us at sales@itunedusa.com also our web site will be down for a month for updates to better serve our customers.
Anthony
itunedusa.com
Old Jan 14, 2006 | 05:18 PM
...Baker's Avatar
so is this legit or what?
PM me a quote for a set (98 Civic Coupe DX) shipped to 49203
Old Jan 16, 2006 | 09:02 AM
Civic DX 4dr's Avatar
are these available with any other rates than 10k/6k?
Old Jan 17, 2006 | 12:31 AM
Retired's Avatar
WEST COAST
Default Re: Buddy Club N+ Suspension $799.99 + shipping (Civic DX 4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic DX 4dr &raquo;</TD></TR><TR><TD CLASS="quote">are these available with any other rates than 10k/6k?</TD></TR></TABLE>
Spring rate are availble in 12k/6k only buddy club recommendations!
Old Jan 17, 2006 | 07:31 PM
SiR-DB8's Avatar
New User
How much for 2004 RSX-S to 94536?
Old Jan 20, 2006 | 08:12 AM
eboixing's Avatar
Default Re: (SiR-DB8)
BUMP
Old Jan 20, 2006 | 05:10 PM
RsxVengeance's Avatar
can i pick up? you got dc5 in stock, i hate shipping.
Old Jan 25, 2006 | 01:02 AM
eboixing's Avatar
Default Re: (RsxVengeance)
so where are they?
Old Jan 25, 2006 | 08:40 AM
Default Re: (xxazn2nrxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxazn2nrxx &raquo;</TD></TR><TR><TD CLASS="quote">so where are they? </TD></TR></TABLE>
You must be kidding, right? Do a search...
Old Jan 25, 2006 | 09:36 AM
eboixing's Avatar
i have. no one has the buddyclub N+ in stock because my friend is the buddyclub distributor and he bought the whole container of N+ coming from Japan. I'm just wondering how they're selling n+ for 850 when they're going for 1050
Old Jan 25, 2006 | 09:41 PM
Halo's Avatar
Is there anything available for the 5th gen prelude?
