How do you prep your materials?
Old Jan 3, 2006 | 03:44 PM
discrete's Avatar
Default How do you prep your materials?
How do you prep your materials before you make a manifold?
I typically grind a little off edges of where I will weld.
Then I take a paper tower and wipe the edges clean of any oil that may exist.
Old Jan 3, 2006 | 04:31 PM
jon volk's Avatar
Default Re: How do you prep your materials? (discrete)
bevel the edges to a similar angle that the elbows come with, wire wheel the whole piece, wipe with acetone, clean filler rod w/ acetone, then weld.
Old Jan 3, 2006 | 06:08 PM
Cincy EG Hatch's Avatar
I'm also interested.
Old Jan 3, 2006 | 10:27 PM
discrete's Avatar
Default Re: How do you prep your materials? (k20 jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20 jon &raquo;</TD></TR><TR><TD CLASS="quote">bevel the edges to a similar angle that the elbows come with, wire wheel the whole piece, wipe with acetone, clean filler rod w/ acetone, then weld.</TD></TR></TABLE>
See, I dont know about the whole acetone thing. I'm hearing it a lot, but it doesnt make much sense to me. If I've already grinded off the top layer of steel, how can the surface be contaminated?
Old Jan 4, 2006 | 04:09 AM
PolyPill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by discrete &raquo;</TD></TR><TR><TD CLASS="quote">See, I dont know about the whole acetone thing. I'm hearing it a lot, but it doesnt make much sense to me. If I've already grinded off the top layer of steel, how can the surface be contaminated?</TD></TR></TABLE>
I do know your grinder can pick up crap and spread it around, like inks and oils.
Old Jan 4, 2006 | 10:55 AM
jon volk's Avatar
Default Re: How do you prep your materials? (PolyPill)
Its alot easier to take a few seconds to clean it w/ acetone rather than chance oils/dirt getting into it and getting a comprimised weld from contamination.
Old Jan 4, 2006 | 03:06 PM
RCautoworks's Avatar
Make sure you try not to touch the area with bare skin or else you can release your body oil into the piece.
Old Jan 4, 2006 | 09:49 PM
Niles's Avatar
Don't forget to give your filler rod a quick acetone wipe as well
Old Jan 5, 2006 | 01:27 PM
Calvinator's Avatar
Default Re: How do you prep your materials? (Niles)
Is there any other solvent that I can use to clean the metal and filler besides acetone?
Old Jan 5, 2006 | 01:43 PM
Default Re: How do you prep your materials? (xtremeazian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">Is there any other solvent that I can use to clean the metal and filler besides acetone?</TD></TR></TABLE>
Why not just use acetone ?
Old Jan 5, 2006 | 04:26 PM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">Is there any other solvent that I can use to clean the metal and filler besides acetone?</TD></TR></TABLE>'
acetone leaves the least residue in relationship to it's price (imho). Buy it and be happy.
Old Jan 5, 2006 | 04:28 PM
Calvinator's Avatar
Default Re: How do you prep your materials? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Why not just use acetone ?</TD></TR></TABLE>
I was just seeing if there was anything else i can use, like something I already have laying around the house
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">'
acetone leaves the least residue in relationship to it's price (imho). Buy it and be happy.</TD></TR></TABLE>
sounds good
BB6racer
Nov 28, 2006 09:15 PM
Quickgti1.8t
Welding / Fabrication
Nov 24, 2006 04:18 PM
jDm_eDm
Aug 18, 2006 05:43 AM
RCautoworks
14
May 1, 2005 10:06 AM
moleodonuts
20
Jun 26, 2004 07:49 AM
