Car dies when I stop- SEARCHED
Old Jan 3, 2006 | 10:21 AM
h22vt's Avatar
Default Car dies when I stop- SEARCHED
Please someone help me.....i have an 01 prelude and when i stop the car just dies or when it gets put into N. but if i give it a little gas it wont die.it will start right back up no problem.i just got a vafc but its not tuned. the car is running rich and im guessing its cause its not tuned? could that be the problem? if not what could it be? thanks for all the help!
Old Jan 3, 2006 | 10:24 AM
budget's Avatar
Default Re: Car dies when I stop- SEARCHED (h22vt)
bump for an answer
Old Jan 3, 2006 | 10:28 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22vt &raquo;</TD></TR><TR><TD CLASS="quote"> the car is running rich and im guessing its cause its not tuned? could that be the problem? if not what could it be? thanks for all the help! </TD></TR></TABLE>
Uh...yeah it needs to be tuned or at least put back to the OEM specs. Fuel pressure, ignition timing, valve lash, idle speed etc should all be checked and adjusted to get it running good.
Do you have any lightweight rotating parts?? I have an 8lb flywheel, UR crank & alt. pulleys, no PS or AC, ST Corsa cam gears and no balance shafts and mine goes way down when I disengage the clutch but doesn't stall out....and all my stuff is set to OEM specs.
Old Jan 3, 2006 | 10:37 AM
h22vt's Avatar
i have i/h/e and aem tru pullies. . .but i still have ps ac. how do i put it back to oem specs?
Old Jan 3, 2006 | 10:41 AM
Hawkze_2.3's Avatar
Default Re: (h22vt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22vt &raquo;</TD></TR><TR><TD CLASS="quote">i have i/h/e and aem tru pullies. . .but i still have ps ac. how do i put it back to oem specs?</TD></TR></TABLE>
Well, do a valve adjustment, set your fuel pressure (might need a regulator and gauge if you don't have one), set your ignition timing and I forgot to mention your cam timing by using the marks on the cam gears and flywheel, and adjust the screw on the throttle body to get the idle higher/lower to where you want it.
Get a manual if you're not sure how to do all that stuff or search on this site and the web.
Old Jan 3, 2006 | 10:45 AM
h22vt's Avatar
thanks for all the help. . . .
Old Jan 3, 2006 | 10:46 AM
Hawkze_2.3's Avatar
Default Re: (h22vt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22vt &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help. . . .</TD></TR></TABLE>
vtecsi00
Mar 5, 2008 12:35 PM
rleonekc
11
Sep 14, 2007 07:55 AM
rider07
Aug 15, 2007 02:12 PM
noob2006
Jun 22, 2006 03:56 AM
ts94h22accord
Mar 22, 2006 04:49 PM
