92 prelude auto si. did jdm h22 swap 6 months ago, just now did the 5 speed swap. red lines @6200 an
92 PRELUDE SI H23 AUTO
DID THE SWAP TO THE JDM H22A VTECH 6 MONTHS AGO KEEPT AUTO TRANY VTECH WORKED THE WHOLE TIME AND REDLINE WAS 7200-7250 CUTOUT 120MPH.
JUST DID THE 5 SPEED SWAP CAME FROM AN ACORD H22 VTECH
KEPT THE SAME ECU FROM THE JDM AUTO SWAP
NOW I DONT HAVE NEAR THE POWER I SHOULD I CANT GET PASED 6200 RPM AND I DO NOT HAVE VTECH UNLESS HARD WIRED 12+ TO MOMRNTARY SWITCH ON SHIFTER TO VTECH SYLNOID <--- I KNOW I SHOULDN'T DO THIS BUT HAD TO TEST IT OUT) IT DOES WORK BUT AGIN NOWHERE NEAR THE SAME POWER INCREASE.
ANY HELP WITH THIS PROBLEM I KNOW IM JUST OVER LOOKING SOMETHING...
COME ON IF IT WERE A SNAKE IT WOULD HAVE BIT ME RIGHT.
__________________
There is a right time and place for everything...
In that time and place there is no right nor wrong,
Drive that fine grey line.
__________________
umm just a guess... but did you swap the ECU's too....manual has a diff ecu. than the auto... and just FYI... VTEC... no H here.. its not the telephones...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">the problem is you are running an automatic ECU with a manual tranny...change that ****...and get ready to be flames..b/c there isnt an H on theend of vtec</TD></TR></TABLE>
and posting in all caps is not a good idea either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeffrey9 »</TD></TR><TR><TD CLASS="quote">I was gonna post my input, but the caps made it way too annoying to read...</TD></TR></TABLE>
cliffs...
did h22 swap with automatic tranny, swapped h22 tranny, kept automatic ecu, now redlines at 6200 instead of the 8000 it should me...
cliffs...
Want to put a 92-95 h22A swap with MT in a 88 prelude that has the 2.0 carb
motor with MT. I have heard the motor mounts are the same. Is this true and how difficult.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racetowin »</TD></TR><TR><TD CLASS="quote">Want to put a 92-95 h22A swap with MT in a 88 prelude that has the 2.0 carb
dude, how did the topic of this thread totally change?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwprs37 »</TD></TR><TR><TD CLASS="quote">Wow, that was the most blatant thread jack I've ever seen....</TD></TR></TABLE>
doesn't matter though, the op already got his answer (needs a new ecu), and to the other guy, 3rd gen preludes came with B series motors.
ekDeadmau5
Jun 24, 2011 06:00 PM
