88 crx pressure plate bolt up to a obd1 d series flywheel?
I had to buy an 88 crx clutch kit because the tranny I am using has an input shaft with 21 gears.
The tranny will be bolted up to an OBD1 d series vtec motor.
My question is this:
Will the pressure plate bolt to the flywheel? or do i have to get a diffrent flywheel?
Thank you.
Thank you.
You will need a new flywheel. The 88 clutch and flywheel is smaller.
Remember. Your clutch and flywheel should match your transmission.
From: I told you to wait in the truck in Texas, United States
Or you can do this:
"The flywheel is a different size and the spline count is different from 88 to 90-91.
You should get a 88 accord disk and 90-91 CRX PP.The 88 accord disk is the correct size for the 90-91 flywheel and has the spline count to match the 88 tranny. ACT also sells what is known as an 88 Upgrade set which works with the 88 tranny and the larger 90-91 flywheel."
LsVtec08
Transmission & Drivetrain
Jan 4, 2011 06:59 PM
vbspec
Jan 16, 2007 10:29 AM
CimorelliCRX
16
Dec 12, 2002 05:13 AM
