How do i remove this fuel hose?
Old Jan 2, 2006 | 10:35 PM
Db1 Supreme's Avatar
Default How do i remove this fuel hose?
i need help trying to take this hose or line, its connected to the fuel filter or somehitng
Old Jan 2, 2006 | 10:48 PM
Luserkid's Avatar
Default Re: How do i remove this fuel hose? (40oz.)
Impact gun always does the trick for me.
You need a wrench on the bottom (i believe a 19mm) to hold the fuel filter and a 17mm to knock off the top bolt. Its much easier to do it with the filter outside the car.
Old Jan 2, 2006 | 11:14 PM
Default Re: How do i remove this fuel hose? (Luserkid)
im removing the motor, should i just take the fuel filter instead of taking off the lines
Old Jan 3, 2006 | 12:39 AM
sitinthehall's Avatar
Could be bad news if those copper washers are squished in there. Just don't break the bolt.... They're probably pretty expensive
Old Jan 3, 2006 | 01:18 AM
Luserkid's Avatar
Default Re: How do i remove this fuel hose? (sitinthehall)
If your just pulling the motor then why not take it off from the fuel rail. Take off that light yellow cap thing and take off the 17mm bolt there.
Old Jan 3, 2006 | 01:49 AM
fmrprojects's Avatar
i'm just curious. how do you know how to take out a motor and not know how to remove a fuel line?
Old Jan 3, 2006 | 01:59 AM
Default Re: How do i remove this fuel hose? (fmrprojects)
trial and error and honda-tech...thats how, thanks for the help i got it off
Old Jan 3, 2006 | 06:26 AM
HatchNaPlan's Avatar
nice post...maybe help the guy out?
Randomnoob
Jan 4, 2019 03:20 PM
magic hat #9
Jan 9, 2009 07:23 AM
moonpieboy
Oct 9, 2005 09:57 AM
94DOHCDELSOL
Feb 4, 2005 11:00 AM
get wet racing
Jan 6, 2003 06:16 AM
