BAD surging idle....I SEARCHED
Old Jan 2, 2006 | 08:59 PM
KB96VTEC's Avatar
Default BAD surging idle....I SEARCHED
a week or two ago, my 4th gen VTEC started surging idle on cold start up (30-40*F). it would bounce from 1000 to 2500 repeatedly until the car warmed up. Now within the past few days, its gotten worse. It doesnt go away when the car gets warm...it never goes away. its getting really embarrasing and EXTREMELY annoying. i searched and found out theres a "screw" or plate that comes loose over time and needs tightening. without taking my CAI off, i closely examined the TB and area around it and only found 1 screw on the TB with a flathead groove in it. this cant be the right screw because i tightened it a little and it didnt effect the rough idle at all. i need someone to show me exactly what i need to do (pics would be nice) to remedy this problem. cars got 112, 000 miles. thnx in advance.
Old Jan 3, 2006 | 07:42 AM
kulrevon's Avatar
Default Re: BAD surging idle....I SEARCHED (KB96VTEC)
you probably have a vaccum leak somewhere. and it sounds like a big one.
try taking off your intake and starting your car. there are two holes in the throttle body. towards the back of the car. try covering one at a time and see if the idle steadys. I believe the bottom hole is for the iacv. or if that doesnt fix it you might have a leak somewhere else. just try finding it its not that hard.
Old Jan 3, 2006 | 08:29 AM
Hawkze_2.3's Avatar
It could be your IACV, FITV, vacuum leak, throttle body screw, leaky IM gasket, or a range of other things. There have been many topics on this subject and tons of info has already been typed...just run a search for some of these things.
Old Jan 3, 2006 | 08:50 AM
AndyD's Avatar
First thing to do is check your coolant level.
Old Jan 11, 2006 | 04:23 PM
92hondalude's Avatar
Default Re: BAD surging idle....I SEARCHED (AndyD)
same thing with mine but mine goes away after it warms up. what could this be?
sorry for jacking thread but dont want to start a new one
Old Jan 12, 2006 | 05:42 AM
flyrod's Avatar
Default Re: BAD surging idle....I SEARCHED (92hondalude)
fitv most likely.
Old Jan 12, 2006 | 10:17 AM
brolli's Avatar
Default Re: BAD surging idle....I SEARCHED (flyrod)
does it still surge if you press the gas pedal a little big? try unplugging hte iacv or the fitv(i dont know what that stands for but im guessing its the same type of thing as the iac) and if niether of these make it quit surging it must be a vacuum leak. well not must but more than likely.
Old Jan 12, 2006 | 10:39 AM
98TypeSH's Avatar
Default Re: BAD surging idle....I SEARCHED (brolli)
are you throwing a code ? If the vac leak is large enough, you will throw an IACV code . Has the pitch/sound of the motor changed ? Another sign of a vac leak. Go over all the gaskest from the intake manifold up. ( manifold gasket, IAB plate gasket, TB gasket. ) Spray a little bit of carb cleaner or something in the suspected area. If you hear gurgling and see bubbles, you found it
Old Jan 13, 2006 | 07:22 PM
Default Re: BAD surging idle....I SEARCHED (silverlude15)
well i took my FITV off my h22 thats going to be swaped in in a few months. slaped it on the h23 TB and now it idels fine. thanks for all the info
Old Jan 13, 2006 | 09:21 PM
BlueLude 94's Avatar
I Had this same problem along tme ago. Its most likely your idle air control valve. But check your vacum hosees just incase.
Old Jan 13, 2006 | 09:25 PM
vinuneuro's Avatar
I had this problem. Fast Idle Valve.
Old Jan 20, 2006 | 03:54 PM
liddlelude's Avatar
Default Re: BAD surging idle.... (vinuneuro)
glad you fixed the problem, something for me to look into although mine's a little different. i think i have a vaccum leak seeing as it rapidly idles up and down sitting in neutral...or TB issue.
FYI, preludes are notorious for the high idle when it's cold (esp. weather conditions) and they normally run hot. hood works great for a heater in winter at the track!
Old Jan 24, 2006 | 08:42 PM
zer0260's Avatar
Default Re: BAD surging idle....I SEARCHED (BlueLude 94)
where is the FITV? picture would be awesome.
Old Jan 25, 2006 | 04:44 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">well i took my FITV off my h22 thats going to be swaped in in a few months. slaped it on the h23 TB and now it idels fine. thanks for all the info </TD></TR></TABLE>
Thanks for letting us know how it turned out. Most people don't.
Old Jan 27, 2006 | 10:22 AM
Default Re: BAD surging idle....I SEARCHED (zer0260)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0260 &raquo;</TD></TR><TR><TD CLASS="quote">where is the FITV? picture would be awesome.</TD></TR></TABLE>
here is a pic....I know it says out of bandwidth but it will be up on the 31st.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for letting us know how it turned out. Most people don't.</TD></TR></TABLE>
Not a problem
thank you guys for telling me what the problem was
DeLSoLRo
20
Apr 23, 2011 10:06 AM
Cuda
Apr 17, 2008 08:40 PM
shadow29485
Feb 21, 2008 01:36 PM
vtec94civic
Aug 9, 2005 03:35 PM
fishman
Aug 15, 2002 07:05 PM
