Just thought i'd share..
Old Jan 2, 2006 | 07:38 PM
h2392si's Avatar
Default Just thought i'd share..
Hey peeps. Recently my 94 ex coupe started to overheat. Did the basics like change the thermostat, radiator flush and a new cap. Still overheated. So i asked what to do next here but no one even responded. So I did a little research and found out that sometimes the sensor on the thermostat housing itself goes out. I forget the name something like coolant temp sensor or fan switch or something. Point is that i changed it and now it runs perfect. Try that next time you find yourself in the same spot after trying the basics. Peace.
Old Jan 2, 2006 | 09:05 PM
Hondaciv95VX's Avatar
Default Re: Just thought i'd share.. (h2392si)
When the car is sitting and idling, does you fan kick on?
Let it idle for 15 mins or so, see if when it gets hot your fan for your radiator kicks on. If it does'nt check your fuses.
Old Jan 2, 2006 | 09:08 PM
dohcVTECeg2's Avatar
Default Re: Just thought i'd share.. (Hondaciv95VX)
good conclusion
Old Jan 2, 2006 | 09:18 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: Just thought i'd share.. (dohcVTECeg2)
It takes my car 20 minutes for the fan to turn on
be patient, and also make sure your lower radiator hose is hot, which also takes time because the thermostat only opens when coolant is hot
dhonda00
Jun 11, 2013 04:14 PM
gitarman2
May 26, 2013 03:58 PM
Thepowderblue
Jun 18, 2012 02:19 PM
Fighterinsnatch
14
May 26, 2007 08:18 PM
hitop
Jan 16, 2003 03:38 PM
