fuel injectors
there are 3 bolts on the fuel rail, then take the clips off of the injectors, then gently pull the fuel rail out, try not to push down or pull up on it too much just pull it straight out
the injectors should stay on the fuel rail and you can just pull them right out, be very careful though to make sure that none of them fall while you are taking the fuel rail off
