My 2.0LSVTEC Dyno, preliminary results
Old Jan 2, 2006 | 06:32 PM
VtecKiDD's Avatar
Default My 2.0LSVTEC Dyno, preliminary results
232whp/152TQ. rev limiter is only 8500.
i was impressed cause the second full pull we did it made 204/154 @8000rpms.
SPECS:
RS Machines Sleeved LS block 84.5mm
89mm LS CRANK
CP Pistons
Eagle Rods
ACL Race Bearings
CTR Crank Pulley
DFE Enterprises Ported ITR Head
Rocket Motorsports valvesprings and Retainers
AEBS manifold ported by DFE Enterprises
310CC Injectors
Skunk2 Pro Series 70mm Throttle Body
Skunk2 PRO 3 Camshafts
Rage Header/Hytech Production Tri-Y header
Compression 12.2:1
there is still LOTS of tuning to do, so pay no attention to the a/f plots. vtec has to be worked on, and i havent revved it out yet.
also, i have a custom RMF 4-1 header with a 3in collector, however it is MILD STEEL and was already starting to rust. i had it sent out to get coated, so i dynoed with the Rage/Hytech header. Im sure the RMF will make more, cause it did on my dyno test.
Ill be cleaning up VTEC and revving it out later this week once i get more time.
TUNED BY JOHNZM using CROME
Old Jan 2, 2006 | 06:46 PM
JDM SLEEP3R's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (VtecKiDD)
good stuff, nice number
Old Jan 2, 2006 | 07:04 PM
StRoKeD-B16bEj2's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (JDM SLEEP3R)
very nice numbers, trying to do a 2.0 build to, but with B20b
Old Jan 2, 2006 | 07:10 PM
Default Re: My 2.0LSVTEC Dyno, preliminary results (BLaCkMaNEg6)
i was thinking of doing a 2.0L build too. After doing some research though and talking to some people i heard that boring the engine out to 2.0L isnt that reliable for DD and isnt worth it, is this true ?
-Sorry dont mean to jack your thread just asking
Old Jan 2, 2006 | 07:12 PM
VtecKiDD's Avatar
cant BORE a b18 to 2.0l, have to sleeve it or run a b20 block
Old Jan 2, 2006 | 07:14 PM
mRvYbEs's Avatar
Good numbers. Where is your vtec set at?
Old Jan 2, 2006 | 07:19 PM
VtecKiDD's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (MRVYBES)
where the giant *** dip is lol
6500ish
these cams are so big you cant hear vtec, its awesome
Old Jan 2, 2006 | 07:25 PM
mRvYbEs's Avatar
lol. I think you should set it a lill higher like 7,000rpm if you haven't done so already.
Old Jan 2, 2006 | 07:30 PM
SMSP's Avatar
Are you running it open header?
Runnerdown's Avatar
Wow, those are some big cams! Wonder what the rmf and about 1000 rpm will bring. Props to you and DFE enterprise
Old Jan 2, 2006 | 07:37 PM
91' LS-VTEC's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (Runnerdown)
Good #'s..
Old Jan 2, 2006 | 07:39 PM
2k.civic.si's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (91' LS-VTEC)
good numbers crome!
VtecKiDD's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (SMSP)
yes this was OPEN header, no exhaust attatched. i had a 4ft extension pipe on the end of the header so i could get accurate o2 readings
Old Jan 2, 2006 | 07:52 PM
Black R's Avatar
25 Year Member
i really like your tq plot.....
if you ignore the dip due to the vtec (which i'm sure you'll get fixed), that is a nice flat graph for the tq from 5600 all the way to 8500 (~150 ft-lb).
Too bad it's wet outside - I'm sure you want to flog that bitch.....
Old Jan 2, 2006 | 08:01 PM
VtecKiDD's Avatar
Default Re: (Black R)
PICS:
Str8Drift stopped by
Rage/Hytech header
FullRace Traction bars, and header clearance
Old Jan 2, 2006 | 08:36 PM
JDM_DC2_2001's Avatar
Default Re: (VtecKiDD)
very good nice numbers man
Old Jan 2, 2006 | 08:59 PM
Aquafina's Avatar
Beastly.
Old Jan 2, 2006 | 09:00 PM
saver's Avatar
Default Re: (JDM_DC2_2001)
with your CR are you going to have it as a daily driver?
good set up and #. i bet after the tune its goint to be so pretty.
Old Jan 2, 2006 | 10:00 PM
shonbz's Avatar
Default Re: (saver)
nice man i been following ur build since u first posted, ***** turning out good man congrats
Old Jan 2, 2006 | 10:07 PM
VtecKiDD's Avatar
itll be a weekend warrior. id like to keep this car to 10k miles a year.
i have a EF beater to drive everyday.
this was on 93 octane BP pump gas
Old Jan 3, 2006 | 01:43 AM
jt-sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">itll be a weekend warrior. id like to keep this car to 10k miles a year.
this was on 93 octane BP pump gas</TD></TR></TABLE>
vteckidd, looks like those cam was still too big on 2.0L form , your got some down valley graph when the vteck kick on 6k. is that lobe centre setup the same as pro 2??
hey, did you dyno it without intake , ?? i see on the pict.
Old Jan 3, 2006 | 04:20 AM
shorto85's Avatar
Once you get the A/F ratios dialed in it should help you out. Not bad #s though at all!
Old Jan 3, 2006 | 06:04 AM
ATS*Mark's Avatar
OG triple OG
Old Jan 3, 2006 | 06:22 AM
jdm_ef9's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (Hella_JDM)
very nice numbers so far.... very curious to see the final hp/rpm.
get that rmf on there also.
were you planning on running itb's?
Old Jan 3, 2006 | 06:30 AM
VtecKiDD's Avatar
Default Re: My 2.0LSVTEC Dyno, preliminary results (jdm_ef9)
i dont see where these cams are "too big ". it makes killer TQ early and holds it well into the RPM range. the WHP is a flat, smooth diagonal line. The dip at vtec is from the low cam and high cam tables not being smoothed together. we have a little more time to spend on that, as i said this is preliminary tuning.
I also KNOW for a FACT that the my motor made 10 less HP with the PRO2s. gotta love an engine dyno
