94-97 Wagon Suspension question...
Old Jan 2, 2006 | 04:31 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Default 94-97 Wagon Suspension question...
I have a wrecked 94 Accord sedan with still good brakes (stock calipers, ebc rotos and green stuff pads) could I take the calipers and associated parts off the sedan and put it on a wagon? Cause I do believe that the wagons have different brakes. Also, the crashed sedan has aftermarket sway bars, struts and springs, would that transfer onto a Wagon? If not, why? If its something like having different mounts, could I take the suspension pieces off a sedan
Old Jan 2, 2006 | 04:33 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: 94-97 Wagon Suspension question... (ComeOnKip)
What model sedan and wagon?
Old Jan 2, 2006 | 04:36 PM
ComeOnKip's Avatar
Default Re: 94-97 Wagon Suspension question... (Vt4cPwn35)
94 ex sedan to 94-97 ex wagon
Old Jan 5, 2006 | 03:18 PM
flight50's Avatar
brakes on the wagons are bigger than sedan. don't think it will work. sway bar not to positive about. most parts for the sedan and coupe will work for the wagon with no modification necessary but these are two that i think are wagon specific. i am part of a wagonclub and this guys are pretty cool with wagon stuff. ask the guys over there to be sure though. here is the link. http://www.accordwagonclub.com/forum/.
Old Apr 16, 2006 | 10:25 AM
MestizoRacer310's Avatar
Default Re: 94-97 Wagon Suspension question... (flight50)
You are correct in which the brakes are indeed wagon specific. The only sedan the wagon shares brakes with is the V6. Regarding the suspension parts they are pretty much interchangeable. However, get ready to do some drilling on the rear crossmember to install the sway bar. But since you have an EX, you may already have the holes necessary to bolt up the mounts.
henry9419
Suspension & Brakes
72
Apr 4, 2012 05:28 AM
gustavito1986
Nov 28, 2008 09:59 PM
strtciv93
Suspension & Brakes
May 30, 2007 02:50 PM
07
May 3, 2005 09:12 PM
