----BIGGEST CIVIC PARTS SALE OF THE DECADE---- (100+PICS)
Old Jan 2, 2006 | 04:23 PM
mike93eh
Guest
Posts: n/a
Default ----BIGGEST CIVIC PARTS SALE OF THE DECADE---- (100+PICS)
EDIT: CRX PARTS ADDED NEAR THE BOTTOM!!
First off, im truly sad if you are on 56k.
This is the continuation thread of my former parting out thread.
https://honda-tech.com/zerothread?id=1438019
<U><FONT SIZE="10">PLEASE READ!</FONT></U>
-ALL PRICES INCLUDE SHIPPING!!!!
-Most of these parts came off a 93 civic si hatchback or some off of a 93 dx.
-I ship everything out either the same day or next day and provide tracking numbers, if applicable.
-I accept paypal (mike93eh@mchsi.com) or money orders. i am paypal verified.
-On the higher priced parts please add 3% if using paypal.
-I may lower pricing if buying multiple parts.
-I may accept some trades.
-Buy with confidence. I have many vouches on hondatech, which you can see here..
https://honda-tech.com/zerothread?id=752612
Here we go...please bump this if you read it.. this took me a whole day to do
and please please please help me get this stuff out of my garage. it's starting to look like a junkyard.
92-95 civic black dash, mint. bare. $35 pickup only!
92-95 hatch glass and rear two windows. tinted. pickup only!
2 sets of 14" steelies with newer tires, pickup only
d16z6 rods and pistons. set of 4, 1 rod bent. $40 shipped
d16z6 crank pulley, with alt., power steering, and a/c. $15 shipped
sohc d16 valve cover, painted wrinkle red, new sparkplug tube seals. $45 shipped
brake booster and master cylinder. i can seperate if needed. $40 shipped for both
all 5 engine mounts. forgot to picture drivers side lower mount. can seperate if needed. $80 shipped for all
d15b7 oem waterpump, new, less than 1000 miles old. $15 shipped
battery tray. $15 shipped
coolant resevoir bottle. $15 shipped
d16y8 pistons and rods. $45 shipped
d15b7 pistons and rods. set of 3. $25 shipped
cam gear. $10 shipped
timing belt pulley. $10 shipped
rear main plate. $10 shipped
pcv chamber. $10 shipped
oil pickup. $15 shipped
fuel rail. $10 shipped
radiator fan. $35 shipped
d16z6 or d16y8 valves. all good. missing one valve. $15 shipped
power steering pump with mount. $40 shipped
brake and gas pedal assembly for manual cars. $50 shipped
clutch pedal assembly. $35 shipped
steering column with switches, tilt, and even key. can seperate parts off it if needed. $100 shipped
wiper motor, just the motor. $20 shipped
cruise control. $30 shipped
battery cables. also includes negative cable but forgot to picture. $10 shipped
thermostat housing. $15 shipped
vacuum box thingy. $10 shipped
sohc vtec spark plug wires, 1 oem set and 1 aftermarket set. $20 shipped
30/40 proportioning valve. $10 shipped
heater thingy. $10 shipped
upper timing belt covers. 1 z6 and 2 y8's. $20 shipped
valve cover. $25 shipped
d16y8 exhaust manifold. almost like a header. heatshield not included $25 shipped
d15b7 oem honda timing belt. less than 1000 miles old. $10 shipped
d15b7 intake manifold. complete with sensors, injectors, and all. $50 shipped
need any kind of plugs? plug for your mini-me? i have many of them!!
srs wiring and sensors. $20 shipped
sensors. $8 shipped each.
coil. works great. $15 shipped
external map sensor. $10 shipped
civic and integra oil caps. $10 shipped
switches. $10 each shipped
d15b7 oem honda timing belt tensioners less than 1000 miles old. (1 sold) $10 each shipped
fast idle thermo valves. $15 shipped
seat bolt covers, clock block off, and sun visor clips. $10 shipped
stock fuel pump. $15 shipped
hatchback emblems. $15 shipped
240cc obd1 injectors. $20 shipped for each set of 4
fuel pressure regulator. $10 shipped
upper radiator hose outlet. $10 shipped
2 new turn signal relays. $10 shipped for both
m3 mirrors. painted captiva blue pearl. $40 shipped
boss 7 band graphic equalizer. $20 shipped.
pioneer cd player. $35 shipped
92-95 alternator. $40 shipped
92-95 top dash vents. $10 shipped
ash tray. $10 shipped
misc. brackets and stuff. $15 shipped
heater core. $50 shipped
heater blower. $50 shipped
lower console. no ash tray or pocket. $15 shipped
heater/ac controls. $30 shipped
hatchback rear side moulding with good clips. both sides. $15 shipped
dome light and hatch light. $15 shipped
cruise control unit. $25 shipped
srs unit. $25 shipped
underhood fuse box. $30 shipped
underdash fuse box. $25 shipped
ebrake handle. $25 shipped
fuel lid. $15 shipped
rubber boots. $8 shipped
oh **** handles and hanger. $15 shipped
all 3 rear seatbelts. $30 shipped
radiator and condensor brackets. $10 shipped
hatch glass hinges and latches. $10 shipped
sunroof motor. works great. $25 shipped
hatch lid cables. $10 shipped
horn. $10 shipped
hatch/trunk and fuel door release. $10 shipped
tailight plugs. $10 shipped
relays. $15 shipped
misc. stuff. $15 shipped
hatch latch. $10 shipped
washer nozzles. $8 shipped
complete A/C kit minus a couple hardlines. everything you need. can seperate if needed.
d16z6 oil pan. $50 shipped.
technics receiver. powers up but nothing from speakers. $25 shipped
mint drivers and passenger side seats. $50 pickup only!
dx tranny. perfect, no grinds, includes clutch. $50 pickup only!
d series flywheel. $45 shipped
timesert headbolt kit for d-series. make a offer. for more info and how-to's go here..
https://honda-tech.com/zerothread?id=1460750
https://honda-tech.com/zerothread?id=1382274
<FONT SIZE="18">CRX STUFF:</FONT>
glovebox, black, mint condition. $35 shipped
mirror assembly. $20 shipped
right side turn signal, amber. $12 shipped
rear hatch tailight cover pieces. $20 shipped
underhood fuse box. $18 shipped
visors and clips. $15 shipped
washer fluid resevoir with motors. $25 shipped
interior pieces. fuse cover, steering column cover, window crank...etc. $25 shipped
wiper arms, inluding hatch wiper arm. $25 shipped
fast idle thermo valve. $10 shipped
headlight baskets/frames. $20 shipped
d16a6 crx si head. complete minus valve cover. for sale up top^ $65 shipped
one wire bosch o2 sensor. has obd0 crx plug on it. $10 shipped
Modified by mike93eh at 3:19 PM 1/11/2006
mike93eh
Guest
Posts: n/a
Default Re: ----BIGGEST CIVIC PARTS SALE OF THE DECADE---- (mike93eh)
<FONT SIZE="5">STUFF ALREADY SOLD:</FONT>
d15b7 timing belt tensioner
starter
hatch latch with wiper delete plugs
hood latch
clutch disc
d16y8 head
ss rear brake lines
d15b7 dizzy
clutch kit
steering wheel
door panels
injen air filter heat shield
d16y8 exhaust mani. heatshield
greddy emanage injector harness
hood release with cable
p28 ecu
rear non speaker panels
gauge cluster
gauge cluster bezel
top center vent
clock
valve cover
vtec pressure switch
visors
cabin wiring harness
glove box
radiator
hatch shocks and hardware
carpet
front seats
shifter/cupholder console
ebrake console
spoiler
headlights
tailights
corner lights
drivers side door
A pillars
antenna
front seatbelts
lower dash plastic
steering column plastic
radio/heater bezel
hatch/fuel release cover
all body panels except for pass. side door
clutch master and slave cylinders
clutch hard and soft lines
throttle cable
clutch fluid resevoir
front speaker grilles
door handle garnish
wipers and washers
exterior door garnish
mirrors
front fender trim
dead pedal
passenger interior door handle
shifter, shift ****, bushings, and boots
Old Jan 2, 2006 | 05:25 PM
mike93eh
Guest
Posts: n/a
now how are you going to let the biggest civic parts sale of the decade slip to page 10?!
Old Jan 2, 2006 | 05:52 PM
impact_blu's Avatar
pm'd..might also want those signal relays, are they mounted under the dash or in the engine compartment?
Old Jan 2, 2006 | 05:59 PM
mike93eh
Guest
Posts: n/a
Default Re: ----BIGGEST CIVIC PARTS SALE OF THE DECADE---- (impact_blu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impact_blu &raquo;</TD></TR><TR><TD CLASS="quote">pm'd..might also want those signal relays, are they mounted under the dash or in the engine compartment?</TD></TR></TABLE>
pm'd. they are mounted in the underdash fusebox.
Old Jan 2, 2006 | 07:07 PM
mike93eh
Guest
Posts: n/a
bump till its all sold..
Old Jan 2, 2006 | 07:29 PM
MiMiK's Avatar
Default Re: (mike93eh)
interested in the stage 1 clutch. pm me.
Old Jan 2, 2006 | 07:36 PM
swatteamtimmah's Avatar
Default Re: (MiMiK)
intereted in hood release with cable. $10 shipped , PM me when ready for paypal.
Old Jan 2, 2006 | 07:44 PM
mike93eh
Guest
Posts: n/a
Default Re: (swatteamtimmah)
pm's replied!!
Old Jan 2, 2006 | 07:57 PM
mike93eh
Guest
Posts: n/a
clutch kit pending!
Old Jan 2, 2006 | 08:07 PM
mike93eh
Guest
Posts: n/a
hood release and cable sold! thanks
Old Jan 2, 2006 | 09:09 PM
mike93eh
Guest
Posts: n/a
d series starter pending!
Old Jan 2, 2006 | 10:51 PM
mike93eh
Guest
Posts: n/a
dont miss out people!!!
Old Jan 2, 2006 | 11:35 PM
mike93eh
Guest
Posts: n/a
good night bump!
Old Jan 3, 2006 | 12:45 AM
BanEL's Avatar
pmd
Old Jan 3, 2006 | 07:02 AM
mike93eh
Guest
Posts: n/a
Default Re: ----BIGGEST CIVIC PARTS SALE OF THE DECADE---- (DHP_MB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DHP_MB4 &raquo;</TD></TR><TR><TD CLASS="quote">pmd</TD></TR></TABLE>
replied
Old Jan 3, 2006 | 08:21 AM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swatteamtimmah &raquo;</TD></TR><TR><TD CLASS="quote">intereted in hood release with cable. $10 shipped , PM me when ready for paypal.</TD></TR></TABLE>
shipped!
Old Jan 3, 2006 | 10:35 AM
mike93eh
Guest
Posts: n/a
bringin it back up!
Old Jan 3, 2006 | 11:24 AM
nasteboyii's Avatar
bump for you
good pics
good prices
good amount of time to get it all on here
d
Old Jan 3, 2006 | 12:38 PM
mike93eh
Guest
Posts: n/a
thanks!
Old Jan 3, 2006 | 01:45 PM
mike93eh
Guest
Posts: n/a
looks like a 20 page thread in the making...
Old Jan 3, 2006 | 04:08 PM
SpeeedFreak's Avatar
free bump....
Old Jan 3, 2006 | 05:16 PM
mike93eh
Guest
Posts: n/a
Default Re: (SpeeedFreak)
pm'd..
also going to be adding a bunch of crx parts here in a few, be on the lookout!
Old Jan 3, 2006 | 06:13 PM
mike93eh
Guest
Posts: n/a
y8 heatshield sold!
crx parts are coming...
Old Jan 3, 2006 | 07:31 PM
mike93eh
Guest
Posts: n/a
