What clutch do I use for a 21 tooth input shaft?
I am putting an obdI D series motor into my EF hatch.
I bought a DX tranny to keep the car cable.
I bought a single cam cable clutch. The pressure plate lines up perfect. The clutch has 20 notches, and the input shaft has 21 teeth. I called the local part store and they said the tranny should have a 20 tooth input shaft.
What clutch do i need to make this combonation work.
I tried searching, but I couldn't find too much info on the input shaft.
Any help will be greatly appreciated.
Thank you.
Thank you.
You can use the later 212mm (90-92) Civic flywheel and clutch if you use the earlier 21 spline Prelude disc. I think it is 84-87 but I don't have the information at home with me.
SiR eF_4door
Jul 31, 2009 08:15 AM
ACRXGuy
18
Nov 23, 2002 10:25 AM
