need help how to bleed clutch master cylinder or slave.
Old Jan 2, 2006 | 12:53 PM
rollercosta123's Avatar
Default need help how to bleed clutch master cylinder or slave.
please help, i just put a new master cylinder for my clutch cause it was leaking and there was no pressure on the clutch pedal, i put on a new one and i try bleeding it, nothing is happening, please help. Where is the clutch slave cylinder? do i need to do anything with that?
Old Jan 2, 2006 | 12:57 PM
Default Re: need help how to bleed clutch master cylinder or slave. (rollercosta123)
whewre exactly is the slave cylinder? i have a 97 accord ex, 4 cylinder
Old Jan 2, 2006 | 01:23 PM
momstaxi's Avatar
the slave cylinder is located on the front of the transaxle, next to the front engine mount...check to see if it is leaking from either the fitting where the clutch line goes into it and around the boot on it...
Old Jan 2, 2006 | 02:11 PM
Default Re: need help how to bleed clutch master cylinder or slave. (momstaxi)
i got it. it works fine
Ajr
Honda S2000
Sep 21, 2014 11:24 AM
03djmAccrd
Jul 8, 2010 01:37 AM
WiLLMaTiX
Nov 8, 2003 11:39 AM
