what is a mini me?
Old Jan 2, 2006 | 11:23 AM
bassofbob's Avatar
Default what is a mini me?
I am new and I have no clue what it is
Old Jan 2, 2006 | 11:25 AM
Stunna MIKE's Avatar
Hes the dwarf from Austin Powers.
Vern Troyer.
Use the search button. This has been covered multiple times.
Old Jan 2, 2006 | 11:28 AM
SD_Lurker's Avatar
HT White Ops
Default Re: what is a mini me? (bassofbob)
A mini me is the single cam version of the LS/VTEC. The LS/Vtec is used with a DOHC head and 1.8 block. The mini me is the single cam version of the LS/Vtec. Do you understand now?
Old Jan 2, 2006 | 11:29 AM
Its a single cam Vtec Head. I.E D16z6, D16y8 ect. On a Non Vtec Block. I.E D16a6, D15b1 ect.
Old Jan 2, 2006 | 11:35 AM
bassofbob's Avatar
I knew it was basically a head swap, I just didn't know what head on what block.
Old Jan 2, 2006 | 11:52 AM
mrsuburban's Avatar
well now you know
Old Jan 3, 2006 | 04:03 PM
delguy's Avatar
Default Re: what is a mini me? (mrsuburban)
well know i know too, but what is the benefit to this head swap?
Old Jan 3, 2006 | 04:09 PM
crxnj's Avatar
Default Re: what is a mini me? (delguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguy &raquo;</TD></TR><TR><TD CLASS="quote">well know i know too, but what is the benefit to this head swap?</TD></TR></TABLE>
You can have Vtec without swapping in an entire motor..Higher compression in some cases..Lower compression in some cases which would benifit you if you want to go the turbo/supercharger route..Its a cheap HP gain..I mean you can find sohc vtec heads everywehere cheap because everyone is going b-series or even k-series now..
Old Jan 3, 2006 | 04:39 PM
delguy's Avatar
Default Re: what is a mini me? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
You can have Vtec without swapping in an entire motor..Higher compression in some cases..Lower compression in some cases which would benifit you if you want to go the turbo/supercharger route..Its a cheap HP gain..I mean you can find sohc vtec heads everywehere cheap because everyone is going b-series or even k-series now..</TD></TR></TABLE>
but when you swap in the vtec head doesnt their have to be a diff ECU because i know thie is a Vtec wire in the originally equiped vtec hondas
Old Jan 3, 2006 | 04:42 PM
89HatchSI's Avatar
what modifications are needed to run a mini-me, i found a d16y8 head on ebay, but it needs cams. Guy says "some modification may be needed, will fir 90-00 sohc"
will it work on my 89 d16a6?
Old Jan 3, 2006 | 04:44 PM
1point7db2's Avatar
You can use alternate methods to engage vtec such as an msd rpm activated switch or a vafc. You can even chip your obd-0 ecu to engage vtec.
Old Jan 12, 2006 | 06:09 PM
BubbleBoyB16's Avatar
ok I know what a mini me swap is but let me ask you guys this....in your own opinion, what is the best combinations for power? IE...d15b8 block and D16z6 head or d16y7-8 head? answers?
Old Jan 12, 2006 | 06:14 PM
I like the A6 blocc with a Y8 Head.
Old Jan 12, 2006 | 06:47 PM
c0nspire's Avatar
Default Re: (Aaron EF9)
a6 with z6 i like.. z6 head flows the best iirc
Old Jan 13, 2006 | 10:14 AM
Default Re: (c0nspire)
I jus gotta d15b8 block and a z6 head....will that make decent power? I also got sum other bolt ons ....pulleys,a cam gear, intake manifold and headers CA intake....answers?
Old Jan 25, 2006 | 10:58 AM
mrsuburban's Avatar
Old Jan 25, 2006 | 01:16 PM
user 98292739's Avatar
i have a a6/z6 mini me with the head shaved a bit. and i went from running 16.5 stock to 14.8-15 with just the head swap, DC intake, and invidia exhaust with no cat. and a chip for my mini me in my p28
Old Jan 25, 2006 | 01:25 PM
.Grimace's Avatar
footwork mastery
Default Re: what is a mini me? (BubbleBoyB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubbleBoyB16 &raquo;</TD></TR><TR><TD CLASS="quote">ok I know what a mini me swap is but let me ask you guys this....in your own opinion, what is the best combinations for power? IE...d15b8 block and D16z6 head or d16y7-8 head? answers?</TD></TR></TABLE>
not a y7 head because it doesn't have vtec
Old Jan 25, 2006 | 06:49 PM
31flavorscivic's Avatar
Default Re: what is a mini me? (PurpleEKHatch)
Word of advice on the b8:
Make sure the piston has 4 valve depressions on it. Some blocks did not have 4, as the heads only have 2 valves per cylinder, and some did.
Just thought ya ought to know.
Old Jan 25, 2006 | 07:42 PM
EGHatch94's Avatar
Default Re: what is a mini me? (31flavorscivic)
Seriously though. USE THE SEARCH!! this is my favorite Mini-me thread, but there are more like it out there! you just need to look. Most questions anyone will have have probably already been answered somewhere in the archives. here:
https://honda-tech.com/zerothread?id=554053
But since we are on the topic: after extensive searching, I have still not recieved an answer to an earlier question. I am thinking about a mini me, but my block already has 180k+ miles, would this be safe w/ the higher compression, or should I invest in a new block as well?
PushnFords
Honda Civic (2001 - 2005)
Jan 10, 2018 09:58 PM
lilmoh16
12
Apr 14, 2008 12:16 PM
ILcrxsi1
Jul 8, 2006 04:49 PM
birdxa
Jan 10, 2005 08:31 PM
igo4bmx
Jun 30, 2004 12:27 PM
