Loobing LSD in my ITR tranny???
Old Jan 2, 2006 | 11:03 AM
handa's Avatar
Default Loobing LSD in my ITR tranny???
Can opening my tranny case and loobing the LSD make the clicking going away. I have a 98 JDM ITR tranny. A transmission shop here said that might help but I never heard of that. Any help fast.
Old Jan 2, 2006 | 11:39 AM
RPRacing's Avatar
ummmm. Id say no. I mean, tranny fluid is lubricant. what type of clicking are you having and under what conditions?
Old Jan 2, 2006 | 11:46 AM
handa's Avatar
Default Re: (RPRacing)
When ever the car is moving its clicking. I rolled my car down a hill with the car off and it makes the click. The faster i go the faster it clicks. When the car is started and juss sitting there no clicking. Just when the car is moving. The transmission shop says its the differential. Just wondering have u guys ever heard or loobing the differential.
Old Jan 2, 2006 | 11:49 AM
RPRacing's Avatar
have you checked your axles?
putting lube will do nothing
Old Jan 2, 2006 | 11:51 AM
handa's Avatar
no i havent but what would cause the clicking due to axles. Seems like its more from the passengar side. There almost brand new. Maybe not in all the way? thanks for the fast replys
Old Jan 2, 2006 | 11:56 AM
Chris F's Avatar
Default Re: (handa)
Yeah, most people that hear clicking, it's the axle.
Good luck nailing it though. Maybe jack the car on each side and spin the wheel in neutral..
Old Jan 2, 2006 | 11:57 AM
handa's Avatar
Default Re: (Chris F)
it makes that clickin in any gear, even in neutral.
Old Jan 2, 2006 | 12:04 PM
RPRacing's Avatar
yeah, it sounds like the axle to me. what kind of axles are they? I would definately put the car in the air and look at the joint boots. See if you have a bunch of grease in the area around the axle.
and are you saying it clicks at a stop to? or just when moving (in neutral and in gear). Axles can click when moving whether its in gear or neutral
Old Jan 2, 2006 | 12:14 PM
handa's Avatar
When the car is at a stop no noise. When the car is at a stop with engine started, no noise. ONLY when the car is moving it makes that click, regardless if the motor is started or not. I have 99 Integra axles. The boots have no grease on them. Cant work on the car till it gets warm outside.
Old Jan 2, 2006 | 12:31 PM
RPRacing's Avatar
i'd put my money on your axle.
Old Jan 2, 2006 | 12:33 PM
handa's Avatar
hmmmm, why would the shop say its my differential. Maybe trying to make some money huh. Well ill try check my axle. Well get back to you guys. Check this thread in a couple days. Thanks for fast replys again.
Old Jan 2, 2006 | 04:37 PM
98 Spec R's Avatar
Default Re: (handa)
Have you checked your speed sensor? The speed sensor can make a clicking noise if it is not fully engaged. Just a thought. Good Luck
Old Jan 2, 2006 | 06:30 PM
handa's Avatar
Default Re: (98 Spec R)
what do you mean by "not fully engaged"
Old Jan 2, 2006 | 08:34 PM
WHTZ's Avatar
Default Re: (handa)
Meaning it's not tighten down properly. Make sure there is no gap between the casing and the sensor it self.
Old Jan 2, 2006 | 09:11 PM
handa's Avatar
Default Re: (WHTZ)
would this make a really loud clicking noise. The problem im having is pretty loud and is speed wise. The faster i go the faster it clicks. The slower.... you guys get it.
Old Jan 3, 2006 | 04:25 AM
WHTZ's Avatar
Default Re: (handa)
Best thing to do is remove it and check it. Just start with the process of elimination...
Old Jan 3, 2006 | 05:34 AM
citrus3000psi's Avatar
Couldn't you jack the one side up and turn the wheel and vice versa? If the click sound was made on both sides then its safe to assume its in the tranny, if its only on one side then it sounds like an axle.
Old Jan 3, 2006 | 10:51 AM
handa's Avatar
Default Re: Loobing LSD in my ITR tranny??? (handa)
i just took out the passengar side axle right now. Is there suppose to be tranny fluid coming out. Theres not a whole lot, but there not little drips either.
Old Jan 3, 2006 | 12:30 PM
handa's Avatar
Just put the axle back in. So my conclusion, its the differential.
Old Jan 3, 2006 | 12:44 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Its not the diff. I'm willing to place my money with everyone else and say its your axle. Where are you from?
Old Jan 3, 2006 | 12:45 PM
cool guy name
Default Re: Loobing LSD in my ITR tranny??? (walker111)
seeing tranny fluid when taking the axle out is normal.
Old Jan 3, 2006 | 12:46 PM
handa's Avatar
Im from IA. It is NOT my axle, im 99.9% sure that it is. What the hell could be wrong with it, I just took it out and inspected it. There was kinda alot of tranny fluid. WHat could be wrong with my axle then guy.
Old Jan 3, 2006 | 12:47 PM
cool guy name
Go to auto zone and get a new axle and put it in.
Old Jan 3, 2006 | 12:49 PM
handa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Go to auto zone and get a new axle and put it in.</TD></TR></TABLE>
Are you serious, what is wrong with the axle I have then? I checked it out nothings wrong with it.
Old Jan 3, 2006 | 12:51 PM
cool guy name
What did you check on the axle? I would much rather pay 30-40 bucks replacing an axle than 500+ on a diff.
