Spun rod bearing, replaced everything, same problem again
Old Jan 2, 2006 | 10:47 AM
ulemu's Avatar
Default Spun rod bearing, replaced everything, same problem again
B16A2, stock internals
I've spuned a rod bearing from rod #3 because low oil.
Replaced all rod bearings, rod and piston #3, and all piston rings just to get some fun removing the head, the crankshaft seems to be fine, no marks on the rod journals.
The car felt good for around 1200 kms, never passed 4.5k rpm, no smoke, no strange noises, no oil consumption.
After 1200 kms I stared to rev higher to 6.5k, after 1400 kms gone 8k rpm about 3 times and a "clic, clic" sound comes from the engine.
Removed rod #3 and the rod bearings were almost completely f**ked, but not spun (i feel lucky), oil level was fine.
So... what do you think is the problem?? bad crankshaft?? bad oil pump??
And: which are my options?
Old Jan 2, 2006 | 10:56 AM
fastrunner's Avatar
Default Re: Spun rod bearing, replaced everything, same problem again (ulemu)
damaged crank, did you check it for out of round?? If you spun a rod bearing twice in the same place and the only part left from the last time is the crank, it would seem that you should replace the crank. That or have it machined and use thicker HONDA bearings to get the correct oil clearances.
Old Jan 2, 2006 | 04:13 PM
ulemu's Avatar
Default Re: Spun rod bearing, replaced everything, same problem again (fastrunner)
Tnx!
Any more opinions?
Old Jan 2, 2006 | 04:18 PM
Jack8788's Avatar
OEM bearings are your best replacement. The other bearings have been known to be junk. Break the bearings in for a longer period of time. Babysteps....
Old Jan 3, 2006 | 07:05 AM
ulemu's Avatar
Default Re: Spun rod bearing, replaced everything, same problem again (Jack8788)
Sure! i'm using OEM parts.
Come on guys, need more feedback
Old Jan 3, 2006 | 07:09 AM
Slow EJ8's Avatar
I was always under the impression that once you spun a bearing the crank was junk. I am not 100% sure on that but especially in your case if its the same bearing being spun, there might be some inperfections on the crank causing it to keep happening. I dont know for sure though.
Old Jan 3, 2006 | 11:59 AM
VTAKKK!!'s Avatar
deffinitly take the crank to a machine shop and get it reground
and deffinitly use honda pearings
Old Jan 3, 2006 | 12:04 PM
Luserkid's Avatar
Default Re: (VTAKKK!!)
When you spun a bearing more then likely the crank is gone. Depending on the damage of course but usually there junk. You should have realy taken it to a machine shop to be looked at and see if they could micro shave and polish it.
Old Jan 3, 2006 | 12:14 PM
ulemu's Avatar
Someone had their crankshaft machined?
Old Jan 3, 2006 | 12:15 PM
dfn_doe's Avatar
If you lost it the first time due to low oil pressure did you do anything to resolve the original problem? New oil pump, baffled pan etc...
Old Jan 3, 2006 | 12:25 PM
ulemu's Avatar
Default Re: (dfn_doe)
The first time was on road racing with 3.5 quarts of oil tops, i think that was the problem.
Does "Check Engine Light" warns because low oil pressure? never lighted up.
Do you think the oil pump is gone?
Old Jan 3, 2006 | 12:33 PM
dfn_doe's Avatar
Default Re: (ulemu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ulemu &raquo;</TD></TR><TR><TD CLASS="quote">The first time was on road racing with 3.5 quarts of oil tops, i think that was the problem.
Do you think the oil pump is gone?</TD></TR></TABLE>
I certainly wouldn't risk another busted engine on it. You might consider replacing it just to be sure and minimally running an oil pressure gauge with a BRIGHT low pressure warning light, this is a common setup for road racing where high-gloading can cause oil to move away from the pickup and the sump to suck air.
Old Jan 3, 2006 | 12:37 PM
D16z6BoostedEK's Avatar
the crank may b warpd!
95dxsir2
Jan 10, 2010 02:53 PM
pjr710
Aug 18, 2008 11:18 PM
pkolaboy
Jan 9, 2008 08:50 PM
Dyzee
10
Apr 28, 2004 11:56 AM
HotWheelz
Nov 2, 2002 10:01 AM
