NEED HELP: car cranks but wont idle????
Okay so yesterday I was swapping out my TB... changed it put everything back together and tried to start it... fires but wont idle... so me and a friend checked everything still wont idle... so I think to myself **** I'll but the old one back on... did that and still the same.... has anyone every had this problem.... any help would be appriated... btw... b16a2 with turbonetics turbo..... thanks in advance... later Mike
ps... changed injectors... redid wiring... now it just idles really really rough and i think it has a little miss too.... help asap. thanks
Modified by slowhonduh93 at 11:36 PM 1/11/2006
Im running the stock map but that shouldnt have anything to do with it... I tried adjusting the screw but to no avail and what do you mean vacuum lines??? I checked them but even if I had a vacuum leak it should still idle
what knid of tb is it, are you using the map sensor from the old tb or did the replacement tb have the map already installed,b/c you can never know if the person you bought it from may have dropped the tb and just passed it along.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhonduh93 »</TD></TR><TR><TD CLASS="quote">Im running the stock map but that shouldnt have anything to do with it... I tried adjusting the screw but to no avail and what do you mean vacuum lines??? I checked them but even if I had a vacuum leak it should still idle</TD></TR></TABLE>
The map sensor has alot to do with it. Did your new TB come with a map on it? If not then idk. But if it did i would try your old one and see what it does. Not throwing any codes right?
I put the old TB back on even and still nothing..... I have a feeling I might have flooded it or something... I get spark... and fuel... but when I took my plugs out it had fuel on it... so Im thinking that its got too much fuel for anything to spark.. hence the no idle but cranks deal... and how do I deal with it being flooded... thanks in advance.... Mike
well now it idles but it is really rough.... if i give it throttle it dies too.... and if i hold it at around 2-3k rmps it just sounds like ***... even rougher than when idling... I dont know what else to do.... anyone help... thanks Mike
xhatchracerx
29
Jul 17, 2003 09:33 AM
