Honing?
Old Jan 2, 2006 | 07:07 AM
CBURKE's Avatar
Default Honing?
Can you hon a motor with the crank still in? I am asking this because I need to replace my piston rings. I don't want to take the crank out when there is nothing wrong there. I also like the keep the factory settings. I also was thinking, wile I'm in there I may as well upgrade the pistons. If I have a B18A and it's a 81mm bore and I get a set of JE 81mm pistons and I good to go even though I will be honing it a bit?
Old Jan 2, 2006 | 07:25 AM
crxluv2's Avatar
Default Re: Honing? (CBURKE)
You have to take the crank AND oil squirters out.
Old Jan 2, 2006 | 07:34 AM
CBURKE's Avatar
Even if I just use a do it your self honer?
Old Jan 2, 2006 | 09:23 AM
hatchinprogress's Avatar
Default Re: (CBURKE)
yeah you need to remove the crank, and if your gonna use different pistons.....your gonna need to get all the rotating pieces balanced (at a machine shop)
Old Jan 2, 2006 | 09:36 AM
CBURKE's Avatar
I don't think anything needs to be balanced just because of pistons. But I could be wrong.
Old Jan 2, 2006 | 09:38 AM
slammedcivicsi's Avatar
I honed my cylinders in the car, I re-used my pistons, and just cleaned them up.
I didnt want to remove my crank when I replaced my rings.
I havent put many miles on the car since I replaced the rings, but thats cause its been visiting my paint shop.
I just used a self honer and lots of oil.
-Brad
Old Jan 2, 2006 | 11:18 AM
CBURKE's Avatar
Cool thanks that is what I think I'll do.
84dime
Sep 14, 2011 06:45 PM
RICHJ
Jul 27, 2004 12:01 AM
allmotorhatch
Mar 3, 2003 09:41 AM
B18EG6
Jan 2, 2003 03:17 PM
Westrock2000
Sep 13, 2002 07:51 PM
