'00SI front seat brackets in EG hatch...
Old Jan 1, 2006 | 10:31 PM
broketuner-Sol_Si's Avatar
Default '00 SI front seat brackets in EG hatch...
I know that the seats themselves will fit but I was wondering if the brackets from the '99-'00 SI will work in an EG hatch. I've been told/read that you can modify them to fit, they fit perfectly(with no mods) and that they won't work at all. To add to the confusion I looked for seat brackets on other sites and they are pretty much universal(88-00). Please help, will the SI brackets fit into an EG????
Old Jan 1, 2006 | 10:36 PM
opiumdaze's Avatar
Default Re: '00 SI front seat brackets in EG hatch... (broketuner-egb16a)
it will fit in 3 of the 4 bolts.. im not sure which one will be left unbolted.
Old Jan 2, 2006 | 02:59 AM
CivicSiRX's Avatar
u swap ur eg brackets over to the si seats, makes it a bolt on affair all bolts and looks stock.
Old Jan 2, 2006 | 05:18 AM
Vero's Avatar
I have done this in my hatch with 96 EX seats which are identical to the 00 Si except for fabric.
The seats will bolt up 3 our 4 holes. The seats sit noticably higher. In the stock EG I had a few inches from the ceiling, with the EJ/EK/EM1 seats my head would touch. I also noticed they sat a bit cocked.
I strongly suggest taking the mounts and brackets off of the EG and putting them onto the 00 Seat. They will bolt up perfectly, you just have to removed part of the cloth and a few hog rings to get to all the bolts. Takes about an hour to do.
Now you have EK/EJ/EM1 seats that sit lower and bolt in perfectly.
Old Jan 2, 2006 | 11:28 PM
Default Re: (Vero)
I didn't find a how to on how to swap out the brackets, so can someone please step me through the process. Thanks in advance.
Old Jan 3, 2006 | 03:00 AM
Vero's Avatar
Default Re: (broketuner-egb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">I didn't find a how to on how to swap out the brackets, so can someone please step me through the process. Thanks in advance.</TD></TR></TABLE>
find all bolts on bracket from one side - remove
repeat for other side
swap brackets with seats
replace all bolts on bracket for same side on new seat
it's seriously like 4 clearly identifiable bolts on each side, if you need a tutorial on how to undo a screw and unhook some cloth...
Old Jan 3, 2006 | 03:25 AM
Expletive!'s Avatar
Default Re: (Vero)
So by using the 92-95 brackets on SI/96+ seats will there be more head clearance than just using the stock brackets off of the 96+ seats?
Old Jan 3, 2006 | 03:44 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (Slaughter)
you only need to swap one rail. then the ek seats, or vice versa will swap into an eg and bolt up like factory. takes all of 10 minutes start to finish.
Old Jan 3, 2006 | 03:53 AM
Expletive!'s Avatar
Default Re: (Rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">you only need to swap one rail. then the ek seats, or vice versa will swap into an eg and bolt up like factory. takes all of 10 minutes start to finish. </TD></TR></TABLE>
Old Jan 3, 2006 | 06:38 AM
nalgas05's Avatar
http://www.geocities.com/bezean/rseat.html
^follow that, its how to swap integra seats into a 96-00 civic but it'll show u what rails and brackets u need to remove. process is similar to putting ek seats into eg's. i've done it lots of times.
Old Jan 3, 2006 | 03:22 PM
Vero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slaughter &raquo;</TD></TR><TR><TD CLASS="quote">So by using the 92-95 brackets on SI/96+ seats will there be more head clearance than just using the stock brackets off of the 96+ seats?</TD></TR></TABLE>
Oh god yes, noticably more.
yeah and then have your head hit the ceiling because your sitting to high. I guess if you're really vertically impared that may be a good thing.
jdmjeff
Dec 21, 2007 02:28 PM
Manolo
May 6, 2007 10:51 AM
nicko360
Mar 30, 2007 12:50 PM
SpecialEdxl
May 25, 2005 09:15 AM
juan
Dec 4, 2002 03:37 PM
