F22 tranny on H22 motor????
sure it will work but you will cause v-tec to disengage everytime it shifts due to the rpm drop. The gear spacing on these trannies is pretty wide because it is geared for fuel ecomomy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">sure it will work but you will cause v-tec to disengage everytime it shifts due to the rpm drop. The gear spacing on these trannies is pretty wide because it is geared for fuel ecomomy.</TD></TR></TABLE>
yes but the gearing can be good for a turbo applications
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollercosta123 »</TD></TR><TR><TD CLASS="quote">soo thats good? right?</TD></TR></TABLE>
umm... and where would you be going those kinds of speeds?
Personally I would rather have an H22 tranny with shorter gears than the F22 with the longer gears.
Naw only if you either have a vtec controller and set it that low or have a chipped ecu... I have a f22 tranny on my h22. I dont fall out of vtec at all. The only time you're suppose to fall out of it is on the 1, 2 shift... My tires spin all the way thru second so I dont have to worry about it.
