valve adjustment changed ARR's
Old Jan 1, 2006 | 07:14 PM
zman's Avatar
Default valve adjustment changed AFR's
I did a valve adjustment the other day and i've noticed that my AFR is about .5 leaner in pretty much all conditions (idle, cruise, WOT) than before the adjustment.
The thing is that i loosened all of the valves, they were all too tight. The jerk-*** that did the last valve adjustment must have adjusted them wrong because they were even tighter than the .006" IN and .008" EX that the cams recommend and i am now currently running.
Is this normal? Or is my PLX M300 starting to crap out on me?
By the way its a 95 coupe w/b16 built head, stage 2 cams, 11.5:1 CR.
Old Jan 1, 2006 | 07:29 PM
2k.civic.si's Avatar
Default Re: valve adjustment changed AFR's (zman)
get another wideband and compare...or get a new sensor and compare...problem with the plx wideband is they dont calibrate to free air the rely on the resistor in the o2 sensor to calibrate to...while when the sensor is new this method works fine...but after some use the sensor it will become inaccurate since the plx is still calibrated to the resistor not actual sensor readings....this is why i bought a innovate lm-1 it calibrates to free air not the resistor...this is how it keeps the guarenteed +-0.1 accuracy only wideband that does it....
Old Jan 1, 2006 | 08:04 PM
zman's Avatar
Default Re: valve adjustment changed AFR's (2k.civic.si)
oh really. I actually have another PLX sensor that i can try.
skylerreniger
Dec 12, 2012 10:05 AM
lowered94accord
May 7, 2007 09:24 PM
97jdmdc2gsr
Apr 8, 2006 01:38 AM
civic889802
Dec 30, 2005 01:04 PM
