zc questions
Old Jan 1, 2006 | 04:35 PM
srt41320's Avatar
Default zc questions
ok - a little new to the whole non-b-series motors - heard of jdm zc motors (sohc/dohc) want to know some stuff about them? are they direct swap for efs? do they have vtec? is it even a good motor choice? (most likely autocross) - im basicaly looking for the best bang for my buck in my crx - cheap and easy is the moto here...thanks
Old Jan 1, 2006 | 06:49 PM
crex23's Avatar
Default Re: zc questions (srt41320)
Yes they are a direct swap, the motor mounts, tranny, etc should all fit fine. They are non-vtec motors, and I believe have about 120-130 hp depending on if you get the sohc or dohc one. So yeah they are pretty good motors. However last time I checked on HMO, they were sold out, so they might be getting harder to find.
Old Jan 1, 2006 | 09:03 PM
kantfadedisazn's Avatar
Default Re: zc questions (crex23)
hahah i have one of those swaps mine is the jdm sohc zc, that swap is exallent for mid range, but thats all going to become a mini me vtec muhahahahahahha
Old Jan 2, 2006 | 02:44 PM
fujiwara takumi's Avatar
in autoX that will put you in a mod class and you will get your *** handed to you frequently. ANY motor swap bumps you to mod in which case youre competing against any b16's, 18's etc. as far as swaps go its cheap, easy, but definetely not the fastest.
However. in terms of balance it is really nice in EFs and even nicer in CRXs so you will have a fast fun car on the track, just dont expect to take home trophies.
If you really want to do well in Auto X you could proly have a lot of luck with the stock 1.6SI motor in the STS class.
Old Jan 2, 2006 | 03:56 PM
srt41320's Avatar
Default Re: zc questions (fujiwara takumi)
whats involved when swapping a si setup - just motor/tranny/ecu/si engine harness?
Old Jan 2, 2006 | 08:38 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 &raquo;</TD></TR><TR><TD CLASS="quote">Yes they are a direct swap, the motor mounts, tranny, etc should all fit fine. They are non-vtec motors, and I believe have about 120-130 hp depending </TD></TR></TABLE>
Not all are non vtec..There is the obd1 sohc vtec zc..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srt41320 &raquo;</TD></TR><TR><TD CLASS="quote">whats involved when swapping a si setup - just motor/tranny/ecu/si engine harness?</TD></TR></TABLE>
Well if you have an hf you just swap in the si motor,tranny,and ecu and thats it..I recommend swapping the hf axles and hubs for si/dx units(Bigger brakes and stronger axles) ..
Now if you have a DX you have to convert your harness to mpfi(4 injectors).
Old Jan 3, 2006 | 02:12 PM
srt41320's Avatar
Default Re: zc questions (Mr.speaker)
thanks for all the info - i have an hf and i also have a si spindles and axles - now i just gotta find a si setup - tahnks again yal!
9db85
Dec 21, 2006 05:51 PM
FastAzzDA
Oct 23, 2006 07:57 AM
Extreez
Jul 21, 2006 03:29 PM
Koble
27
Jan 9, 2006 07:24 PM
contender
Jul 2, 2005 08:14 AM
