poor mans type r??
Old Jan 1, 2006 | 04:00 PM
bigmikerich20's Avatar
Default poor mans type r??
my friend has been talking about gettin a poor mans type r. CaN anyone tell me what this motor is?
Old Jan 1, 2006 | 04:05 PM
TypRice's Avatar
poor mans GSR...
b18/b20 block(non vtec)
b16head/b18head(vtec)
Old Jan 1, 2006 | 05:25 PM
Shawn C's Avatar
In The Garage
a poor man's type-r engine is a P72 block (gs-r block, but also same block that type-r is), a PR3 head (b16 head, same as type-r), high compression pistons, type-r cams, etc...
and for future question's like this one, don't make a post about it on h-t, just ask your friend who is talkin about it.
Old Jan 1, 2006 | 05:30 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (ShadyEH2)
Whatever it is, it doesn't belong in this forum...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR Forum Guidelines &raquo;</TD></TR><TR><TD CLASS="quote">Rarely-allowed OT content
There are lots of forums in here. If there is a forum that fits your question better than this one, it will be locked/moved/deleted.</TD></TR></TABLE>
Old Jan 2, 2006 | 06:44 AM
batmang yO!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">a poor man's type-r engine is a P72 block (gs-r block, but also same block that type-r is), a PR3 head (b16 head, same as type-r), high compression pistons, type-r cams, etc...
and for future question's like this one, don't make a post about it on h-t, just ask your friend who is talkin about it.</TD></TR></TABLE>
first off, there's is no such thing as a p72 block true the GSR block (b18c1) and the type R block (b18c5) are the same casting. And the b16 head is not the same as the type R, there are plenty of difference in the two.
And to answer the original question. A poor mans type R is any non-vtec block with a v-tec head on it.
non-vtec engines...
b18a
b18b
b20
slap a v-tec head on one of those engines from a GSR (b18c1) , Type R (b18c5), or an Si (b16) and you got your self a "poor mans type R" or as most people call it an ls/vtec setup, which is not a good idea unless you know what your doing.
so for future reference, don't post unless you got an answer to the original posters question, just save yourself the trouble and push the back button on your browser.
Old Jan 4, 2006 | 08:20 AM
slow91crx's Avatar
Default Re: (Beavis)
beavis you are wrong bud. a poor mans type R is a gsr block with a b16 head and itr pistons and cams...
the rod/stroke ratio or a b20/b18 non vtec block is way different than that of a gsr/type R.. so therefore there are no similarities between those b20 - ls/vtec combos and a TYPE R.. don't act so smart because you obviously don't know what your talking about.. they call it a poor man's type R because that setup shares very similar numbers and with some port work and springs/retainers and cams the B16 head can be made the same as the type R head. and the type R has the same block basically as the gsr other than the pistons which when you change them to type R you will ahve yourself a type R motor for half the price ... which brings the name ' poor man's type R' to make alot of sense...
Old Jan 4, 2006 | 09:39 AM
Madspeed's Avatar
Default Re: (slow91crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx &raquo;</TD></TR><TR><TD CLASS="quote">beavis you are wrong bud. a poor mans type R is a gsr block with a b16 head and itr pistons and cams...
the rod/stroke ratio or a b20/b18 non vtec block is way different than that of a gsr/type R.. so therefore there are no similarities between those b20 - ls/vtec combos and a TYPE R.. don't act so smart because you obviously don't know what your talking about.. they call it a poor man's type R because that setup shares very similar numbers and with some port work and springs/retainers and cams the B16 head can be made the same as the type R head. and the type R has the same block basically as the gsr other than the pistons which when you change them to type R you will ahve yourself a type R motor for half the price ... which brings the name ' poor man's type R' to make alot of sense...</TD></TR></TABLE>
yep...what he said.
Old Jan 4, 2006 | 04:02 PM
Beatkidd's Avatar
Default Re: (Madspeed)
Old Jan 4, 2006 | 04:15 PM
white rocket's Avatar
Default Re: (Beatkidd)
^^^^^^^^^^^that **** is priceless!!!!!!!!!! lol
Old Jan 4, 2006 | 05:29 PM
m R g S r's Avatar
Default Re: poor mans type r?? (bigmikerich20)
there are a few different ways of doing poor mans...
Old Jan 5, 2006 | 01:42 AM
BGWarren's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beavis &raquo;</TD></TR><TR><TD CLASS="quote">
shut up beavis. theres good to it, its called stroke and if you do b20 its called bore and stroke
i said stroke
Old Jan 7, 2006 | 07:44 PM
chrisgottigsr's Avatar
beavis your a butthead
Old Jan 8, 2006 | 08:38 AM
88 rex's Avatar
Default Re: (chrisgottigsr)
^^lololol
Old Jan 13, 2006 | 08:52 AM
slow91crx's Avatar
Default Re: (88 rex)
Old Jan 13, 2006 | 10:01 AM
Brewer's Avatar
I've got a very simple setup I consider "poor man's type r"
GSR block
P30 pistons
GSR head
ITR valvetrain
'01 ITR cams
Put down 178whp and 130tq at 92-degree ambient temp and 70% humidity
bus stop's Avatar
I think poor man type-r is any honda with the OEM TYPE-R sticker
Old Jan 13, 2006 | 10:18 AM
1GreyTeg's Avatar
Default Re: poor mans type r?? (bus stop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bus stop &raquo;</TD></TR><TR><TD CLASS="quote">I think poor man type-r is any honda with the OEM TYPE-R sticker </TD></TR></TABLE>
I beat a civic up a hill on the parkway in my Yukon today, does that count as a "poor mans Type R"?
Old Jan 13, 2006 | 04:28 PM
v-tec maz's Avatar
Default Re: poor mans type r?? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">there are a few different ways of doing poor mans...</TD></TR></TABLE>
yea evan, i thinkim gonna go this route instead of boost
Old Jan 13, 2006 | 04:48 PM
Shawn C's Avatar
In The Garage
Default Re: (Brewer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brewer &raquo;</TD></TR><TR><TD CLASS="quote">I've got a very simple setup I consider "poor man's type r"
GSR block
P30 pistons
GSR head
ITR valvetrain
'01 ITR cams
Put down 178whp and 130tq at 92-degree ambient temp and 70% humidity </TD></TR></TABLE>
^--- i built and tuned that engine
i wish i had seen beavis's reply to my post. i would have made him cry like a little biatch.... damn what a shitload of misinformation.
"theres no such thing as a P72 block" then why the f-uck is P72 stamped into gs-r and type-r blocks?? also stamped onto gs-r heads, gs-r/type-r oil pans, etc..... ****** retard.
damn that pisses me off. "don't post unless you know what you are talkin about"
man, if you knew me... damn.... aghhh.... i've built and tuned a shitload of honda engines, in all different combinations, made awesome power on all of them. there's probably not a thing you could teach me about them. i'm sorry to sound stuck up or something like that, because i'm not, but damn. i'm glad your *** got stallowned. go put your misinformation back into your *** where it came from and sign back onto clubsi.com. ****** ricer
now i need a beer
Old Jan 13, 2006 | 11:37 PM
0554's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShadyEH2 &raquo;</TD></TR><TR><TD CLASS="quote">^--- i built and tuned that engine
now i need a beer </TD></TR></TABLE>
haha burned. that is one of my biggest things that **** me off, is when i know i am right. then some dumbfuck comes in and says i ''heard"" this or i ''think''. god damn mother ****** i dont hear or think i ''KNOW'' haha. sorry just had to rant.
Old Jan 14, 2006 | 02:11 AM
ff terror's Avatar
too old for school
A type r is already a poor man's sports car to begin with... so its sad that there is a poor man's version of the type r.
Old Jan 14, 2006 | 08:38 AM
Spoogen_1's Avatar
Default Re: poor mans type r?? (neo_)
I think hes talking about an RS.
Old Jan 18, 2006 | 08:28 PM
.::miLan's Avatar
Way to make the guy feel welcome. Thumbs up to you. You really got to love how many people think they are a moderator on H-T.
Old Jan 18, 2006 | 08:36 PM
integtonx's Avatar
Default Re: (.::miLan)
a basic sum up....
1) "gsr block" same as type R
2) b16 head same as type R
3) with type R internals/specs
Old Jan 19, 2006 | 07:52 AM
BolivianDc2's Avatar
Default Re: (integtonx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integtonx &raquo;</TD></TR><TR><TD CLASS="quote"> a basic sum up....
3) with type R internals/specs</TD></TR></TABLE>
don't forget the type R valve cover too
